Antifreeze problem under the mat
08.05.2020 16:34 # 1
Gokhan_S
friends, the weather here is very cold-I caught my attention between -20 and 30, there is a puddle under the mat and the color is green, the antifreeze color is green, what is the problem? if there is a problem, what is the cost?
08.05.2020 16:34 # 2
peugeotefe
Your heating radiator is drilled
08.05.2020 16:34 # 3
Gokhan_S
There was water accumulation for about 1 month, I just noticed its color today. How long can I handle this situation? What does it cost
Gökhan_S 2012-02-03 19:03:54
08.05.2020 16:34 # 4
If you search the forum, you can reach many big information about the subject.
08.05.2020 16:34 # 5
nurinuri58
The brother had the same problem with me. I checked it for 3 4 months. & Nbsp; I went to the industry to get it done on Saturday. I searched a lot and even opened a topic in the forum. When I went to the first master, they said, we will completely remove the chest. but the 206 cars come out on the right side of the pedals. Look at tomorrow, this heater under the cover made of a soft material like foam on the right side of the pedals. & nbsp; If I was there, I would unscrew that cover. It provides three screws to connect the pipe and the honeycomb from the motor, two of mine & nbsp; have become loose and fall over time & nbsp; They tightened screws with nuts and tightened. I mean honeycomb. I think there might be such a problem with you. open the cover there. & nbsp; Maybe the screws are loose, maybe the tires that are called the orling between this link are old. How happy we are if we helped
08.05.2020 16:34 # 6
Gokhan_S
My brother, thank you very much tomorrow, my first job will be to do what I know, there is no peugeot service in a place like pain. Let's hope it doesn't cost me anything :(
08.05.2020 16:34 # 7
djchaos
Make a call with a video narration on this topic
08.05.2020 16:34 # 8
ganjanium
Until you go to the mechanic, you must turn off the heater completely and bring the temperature knob to the coldest point, otherwise the engine water of the vehicle will run out. Since antifreeze is an oily substance, I recommend you to put a newspaper under the mop (I did so)
get past ...
08.05.2020 16:34 # 9
Gokhan_S
When you say engine water, I think you are talking about the antifreeze and water mixture in the radiator !! weather conditions are bad and & nbsp; -30 & nbsp; At -35 degrees, there is antifreeze reduction, we can supplement it with addition, under what conditions do I need to use the vehicle and what measures should I take until the main thing is to repair it? friends, I do not have a branch, the air drops down to -40 at night. How would you recommend to protect the engine part of the vehicle, that is the front side?
08.05.2020 16:34 # 10
Until [QUOTE = ganjanium] goes to the mechanic, you must turn off the heater completely and bring the temperature knob to the coldest point, otherwise the engine water of the vehicle will run out. Since it is an antifreeze oily substance, I recommend you to put a newspaper under the mop (I did so). it does not cause a change in the amount or temperature of the water passing. So this process has no use to our friend asking the question. & Nbsp; Reviews
