Antifreeze is flowing into 206 vehicles !!!
08.05.2020 15:00 # 1
Cetinler
I put antifreeze on my 2005 model 206 vehicle 3 days ago, antifreeze that we put in for 3 days, flows into the vehicle from the inside of the chest next to the gas pedal of the vehicle.
08.05.2020 15:00 # 2
qEccE
I think there is a crack hole in the heater core
08.05.2020 15:00 # 3
or it may leak from the pipe clamp.
08.05.2020 15:00 # 4
erdal
Before you go to the master, I think before the antifreeze level of the vehicle drops.
08.05.2020 15:00 # 5
Cetinler
I do not understand how this problem occurs in a 2005 model vehicle.
I took it to the master, the boiler was burst, said the chest had to be removed in the change. Ağlama
100 lira auto electrician hand labor to remove and wear the chest
70 TL heating core
15 TL re-antifreeze
30 TL repairman manual labor
215 TL in total and 1 day without a car.
on top of them, they can't fit their chests, they break, they pour, and then if you don't have a job go go.
In another malfunction, he had said to me, `` These are only so far '' for what he couldn't do properly to me. Alkış
08.05.2020 15:00 # 6
anafarta
I was with me 1 week ago, I took it to the master, without asking you to ask for other masters if you did not make it for 40 TL.
08.05.2020 15:00 # 7
GiTaRRa
friends have paid so much but it was a pity. now my friend has changed this antifreeze or the ground crack in the pipes has an antifreeze effect when seeing it, the little crack started leaking immediately ... !!!
but you never have to take off your chest or renew your heating comb.
I forgot the name of two pen-thick pieces of powder in the form of powder. .. When the car cools again, look again, because the drop is at least 2 glasses reduced by drop. This is enough to burn the top cover gasket. The vehicle will overheat. ..I hope I could help.
gitarre 2010-12-28 17:56:22
08.05.2020 15:00 # 8
GiTaRRa
I have forgotten, in addition to friends, 5 lira is worth the master's hand, 10 lira is worth a total of 15 lira.
08.05.2020 15:00 # 9
Cetinler
how could they do it without disassembling, if the problem was in the heater honey how could they do it without disassembling in the chest, I would appreciate it.
08.05.2020 15:00 # 10
erdal
I guess they can do it without breaking and pouring in the service ..
08.05.2020 15:00 # 11
Cetinler
The master I asked said if the medicine had a radiator that would not penetrate to the heater core.
08.05.2020 15:00 # 12
Cetinler
[QUOTE = 206xt] I guess they can do it without breaking and pouring in the service .. [/ QUOTE]
Thank you sagola Allah not give it to you
08.05.2020 15:00 # 13
I think we are talking about the radiator plugging product. he can write "radıator stop leak" on it in english.
