Antifreeze hk ..
08.05.2020 20:18 # 1
Askin
Hi nice people Do you need to change my car's automatic transmission oil oil by age of 47 thousand in 2004 pejo, also tsk.
08.05.2020 20:18 # 2
talip206
You'd better change the oil, otherwise it would break the solenoids and cost more.
Antifreeze brand is not very important. At the moment, do not put antifreeze in your car, or do not put it in direct antifreeze and mix it with water. Because if there is water before, it adds antifreeze and bursts somewhere.
08.05.2020 20:18 # 3
Askin
Tsk.talip bey
08.05.2020 20:18 # 4
ggitaristt
I recommend you to take antifreeze from totaly. But if the previous antifreeze is green, take it red if it is red and red. Antifreezes are always different and can damage the car when mixed. Steady with experience ..
If you ask me, drain the antifreeze 1-2 times, fill the water until you open the thermostat. Pour the last 3 liters of red antifreeze. Complete with water .. (red, green, one organic and mineral)
08.05.2020 20:18 # 5
Askin
There is no antifreeze in my vehicle, there is no rusted pure water, unfortunately, I just wanted to get information about how I should take it because I just bought it.
08.05.2020 20:18 # 6
Askin
Do you think red is better?
08.05.2020 20:18 # 7
Oktkor
[QUOTE = Askin] Do you think red is better?
If you ask the previous owner, how did he use it? Antifreeze may look like rusty water after a while. Well, there is no problem. Badly he misses the gaskets like mine, worse he misses the pipes. I don't think you need to think about the worst possibility.
He is 13 years old, but the car has not built 50 thousand km.
08.05.2020 20:18 # 8
oguzhan53
You will buy castrol or inorganic antifreeze in total 3 liters of blue color, it will cause water to escape from the oring of the red radiator core, you will provide protection up to -35 degrees when mixed with pure water in 3 liters.
08.05.2020 20:18 # 9
Askin
Istar
The meat was taken from an older sister, the vehicle looks serviced, 1.5 years ago, but I did not understand why the color of the water was so
08.05.2020 20:18 # 10
Askin
Oguzhan, as you say, I'm getting blue tsk.
08.05.2020 20:18 # 11
ggitaristt
[QUOTE = Askin] Ist
The meat was taken from an older sister, the vehicle looks serviced, 1.5 years ago, but I did not understand why the color of the water was so [/ QUOTE]
Once it starts to rust, it's hard to come back. When it is used with water for a long time, it will start to rust if there is a little water.
You put the green antifreeze, (it will not be red anymore anymore .. It can do the incontinence, it will make the sediment ..) then check the leaks, the car can escape when it gets hot .. If there is no leak, check the color of the water once in the installation. , or how long will it take to break down ..
08.05.2020 20:18 # 12
Askin
Okay, I put the green and test it occasionally.
