Antifreeze depletion
08.05.2020 18:25 # 1
iso307
Friends greet everyone. I need your urgent help. My car 2004 model 307 1.4 HDI.
In my car, there was an error of cooling water missing. I checked the antifreeze was reduced. Half antifreeze was cut off. Let me drip from the engine block, which corresponds to the right bottom corner of the air filter. I wonder how much trouble can be eliminated where this place can be.
08.05.2020 18:25 # 2
hsnsnl
Sank running around where the thermostat is ..
08.05.2020 18:25 # 3
iso307
Sir, I have a photo, but I couldn't add it. Could there be a circulation pump, is the circulation pump located on the right side of the engine or on the left?
08.05.2020 18:25 # 4
iso307
Friends, who would you recommend to me who understands a reliable peugeot repair in Bursa?
08.05.2020 18:25 # 5
307Mster58
If I evaluate my vehicle 1,4i 16V sport from your own car, the outlet pipe of the radiator in the circulation may be damaged, I guess it will not be much more than 50-60 TL.
08.05.2020 18:25 # 6
C@GL@R
There is a radiator occluder I put it cut. try
08.05.2020 18:25 # 7
iso307
According to your opinion and other research that I have done, I think it is around the water collector (slab) or thermostad. It was good to have a preliminary information to a master at the first opportunity. Thank you for your interest.
08.05.2020 18:25 # 8
iso307
I do not think that the clogging powder will solve the problem, not in the radiator, but in the engine body.
08.05.2020 18:25 # 9
C@GL@R
It is not in my radio, it is already missing from the surrounding of a pipe.
08.05.2020 18:25 # 10
iso307
I guess we are antifreeze
is missing from the thermostat gasket ..
08.05.2020 18:25 # 11
iso307
Does anyone have information about thermostat removal. Is thermostat gasket sold separately?
08.05.2020 18:25 # 12
pierson
Slm..you changed the antifreeze of my car .. not taking it all. I put water as it decreases ... now we have a little more antifreeze ... if I put it in place of water? How long should I look at this antifreeze..It seems to be cut off to me too much ... I wait for a month of water or every two months ..
08.05.2020 18:25 # 13
simsek 307
I just looked at the antifreeze. I didn't know if I would add a minimum level ??
08.05.2020 18:25 # 14
Bugra
[QUOTE = lightning 307] I just looked at the antifreeze. I didn't know if I added at minimum level ?? [/ QUOTE]
If it is at the min level, you should add water to the normal level. if there is continuous reduction, you need to show the master
08.05.2020 18:25 # 15
Bugra
[QUOTE = pierson] Slm..you changed the antifreeze of my car ... not of course. as I decreased, I put some water ... now we have a little more antifreeze..will i replace it with water? how much time do i need to look at this antifreeze..it seems to be cut off to me too much .. i wait for a month of water or every two months .. [/ QUOTE]
antifreeze must already be diluted to a certain extent. not completely antifreeze fluid in the vehicle
08.05.2020 18:25 # 16
iso307
Friends today I dismantled the antifreeze leaking thermostat. The dismantling work was quite difficult because it was a narrow point where the transportation and switch maneuver was difficult. As a result, I removed the thermostat. In this way I put the thermostat in place and let it dry for today.
Friends antifreeze, the help I expect from you, from which points do we get the air after putting on the radiator, the engine had to work while taking the air, and is there any other step to be done?
I will put your antifreeze as the end of the job tomorrow. I am waiting for your help in this regard.
08.05.2020 18:25 # 17
C@GL@R
While the engine I know is working, there is a valve in the radiator and I bought it in alpha. There is a valve in the pejo.
08.05.2020 18:25 # 18
oguzhan29
Last week, I changed the thermostat, it was missing from the thermostat.
