Antifreeze and wiper water
08.05.2020 20:39 # 1
tsufrankwoli
I live in Ankara, they looked at the cooling water gasoline -20 degrees output is enough. And if we put glass wiper soap on the windshield wiper water on the anti wiper, would that be harmful?
08.05.2020 20:39 # 2
Alicilik
Hello there,
It is possible to see the -25 people in Ankara, this is also related to the region you live in. I am in a flesh, I don't see it as cold but the ones on the Oran side or the mountains are on the mountain side. It is useful to bring it to -30 equilibrium.
For wiper water, wurth has blue water, it should be 50 or 100 ml.
08.05.2020 20:39 # 3
tsufrankwoli
[QUOTE = Acquisition] Hi,
Thank you.
08.05.2020 20:39 # 4
yigit_dark
Use wiper water with anti-freeze. As soon as it falls to the minus, it will cause you problems on the way to freeze. In snowy weather.
08.05.2020 20:39 # 5
tsufrankwoli
[QUOTE = yigit_dark] Also use wiper water with anti-freeze. As soon as it falls to the minus, it will cause you problems on the way to freeze. In snowy weather. [/ QUOTE]
Thank you, anti fires now, if we add soap on it, will anything happen?
08.05.2020 20:39 # 6
Oktkor
A101 bim.
Get 5 lira. Use sheep.
How many years have I been doing the same. No problem.
08.05.2020 20:39 # 7
tired06
I always used it up to -30 / -35 degrees, I live in Ankara, 30/35 is better when my master says, buy glass water for ankara, put it in a market
08.05.2020 20:39 # 8
tsufrankwoli
[QUOTE = Oktkor] A101 bim.
How many years have I been doing the same. No problem. [/ QUOTE]
Thank you. There is currently a new wiper from him, but he does not clean it. If the sun hits or something, there is always a trace. It almost never cleans.
[QUOTE = tired06] I have always used up to -30 / -35 degrees, I live in Ankara, 30/35 is better when my master says, buy glass water for ankara, put it in a market [/ QUOTE]
Thank you. Some money will go now:. Glass water quality is not a must, hodja.
