antifreeze
08.05.2020 17:16 # 1
blinddark
Hello, I got out of work today, I came home, everything was normal, but I parked my car, handbrake frozen, I pulled a little something, I let it go, but I pulled it and did not leave it. 50 meters after the hose was removed from the top and the antifreeze started to discharge, I wrote on the pc and the steam rose from under the hood, rose from 90 to 95 in the temperature, I added 1.5 liters of water from the house, the drum and the container was full, I changed the antifreeze from about 1 month ago, but in this way I will change the antifreeze completely from the beginning. Wouldn't it be a problem? & nbsp; I still hold 1 tooth in the hand brake, as if my car was forced to get my foot off the gas and wasted slow, I got very bruised, broke down because of my mistake, I got angry I was waiting for your car 307 diesel comments
08.05.2020 17:16 # 2
Serkan
Hodja, go to the nearest petrol station. I always apply the handbrake -7 -8 saw the vehicle has never been frozen so far
Serco05 2013-01-08 17:53:21
08.05.2020 17:16 # 3
blinddark
[QUOTE = Serco05] Hodja, go to the nearest petrol station, antrize your criteria, make it necessary if necessary, there is no need to risk it. I always apply the handbrake -7 -8 saw the vehicle has never been frozen until now
I have seen our passes here -12, it is very cold in the passing nights but frosty and wind freezes too soon but 2 I took it in seconds & downloaded it & nbsp; but did not leave it in general
08.05.2020 17:16 # 4
blinddark
guncel
08.05.2020 17:16 # 5
tellotello
Sir, do you know what the previous antifreeze rate was? If the antifreeze amount previously was sufficient, the amount you put in will not be a problem. You control it without operating it in the morning, you open the hood and then start it well. If you are having a lot of trouble, Serco can be controlled even in oil as my teacher said. For the parking brake, it is very cold at night here (İlker), but for now, there has never been any freezing. It will leave on its own for a while after warming up. Get well soon.
08.05.2020 17:16 # 6
blinddark
[QUOTE = tellotello] Sir, do you know what the previous antifreeze rate was? If the antifreeze amount previously was sufficient, the amount you put in will not be a problem. You control it without operating it in the morning, you open the hood and then start it well. If you are having a lot of trouble, Serco can be controlled even in oil as my teacher said. For the parking brake, it is very cold at night here (İlker), but for now, there has never been any freezing. It will leave on its own for a while after warming up. It should be a long time. [/ QUOTE]
thank you, my holy god, it shouldn't show anyone, it was the last 1.5 months.
08.05.2020 17:16 # 7
blinddark
I leave the gear in gear so as not to pull the handbrake, but when I get back in the car, the brake is so hard like a stone.
