anti-pollution faulty !!! I will get crazy
08.05.2020 17:26 # 1
msk_sansal
If you want a research, the subject was very relevant. it was the weekend. folks could not view the forum.
08.05.2020 17:26 # 2
Serkan
Sir, finish the diesel in the tank, then refill it from a common station, and the problem should probably be solved.
08.05.2020 17:26 # 3
Serkan
If the problem is resolved, the light goes out, hodja.
08.05.2020 17:26 # 4
cerci07
the floor may be clogged if you want to check
08.05.2020 17:26 # 5
cerci07
can make it clean
08.05.2020 17:26 # 6
cerci07
I was very confronted with the error of fap due to antipollution and turbo pressure at 80-90 thousand
08.05.2020 17:26 # 7
cerci07
1.6 hdi 110 fap
08.05.2020 17:26 # 8
cerci07
[QUOTE = onurazgin] I think you said fap my particle filter ?? Did you solve the problem by changing the cost? [/ QUOTE]
particle filter solved the problem by canceling
08.05.2020 17:26 # 9
umutn
First of all, get past, I got this error in my 308, the car was the first time, then I started it again by starting and started for about 30 km. They said that it may be due to the diesel filter, and they changed the diesel filter, another piece that I could not remember but cost around 150-200 TL, and the error disappeared after these operations. About 1 km after starting 600 km, I got the same error and went to the service for about 10 km in traction etc. I had no problems, the car did not have a problem in over 3000 cycles, they connected the computer in the service again, error codes appeared, added the master fuel additive, I added the car to the tank later, after that, when I went down to the half tank, he added a further contribution, I added to the half tank again recently. , even if we said what happened to the error, even though we did not delete the error while in service, it disappeared by itself when it started the car, it was probably a problem caused by dirty fuel, the master said, because all the necessary parts have changed, he said, there is one more possibility, the room fuel pop causes such an error. He said that the cost starts at 2000 TL, and we say goodbye to God bless it, I hope we will not have such a problem, journey to everyone without accident.
umutn 2013-03-23 22:23 : 42
08.05.2020 17:26 # 10
ahmet_bjk
Congratulations you have solved your problem ...
Me too, the air flow meter turns on the malfunction lamp. I am thinking of cleaning the air flow meter. Can you share how and with what you clean?
08.05.2020 17:26 # 11
cezmi3458
I had the same mistake twice in both of them after I bought gas from opet. He gave the same error yesterday, after using the vehicle overturned, he improved, but I could not understand that both of them were after opet.
08.05.2020 17:26 # 12
hsnsnl
I recommend a total excellium
