Anthem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
08.05.2020 15:33 # 1
muntehaozen
Hello, my brothers and sisters, I just became a new member of the site.
My car is using 2004 model 1.6 Gasoline 307 (lpg not installed) but recently the problem is;
1-When I start the car in the morning, it runs in a single starter, but after it starts, it makes a noise like `` çııızt '' until it leaves the ignition.
2-I started the car, 5 minutes passed, I stopped in the situation that I had to stop after making an average of 5 km or so, then when I started the engine after 1-2 minutes, the car does not work.
I want to take advantage of your experience. As I know, there are a lot of people trying to pile up because of my age. I need your information.
08.05.2020 15:33 # 2
ose
Starter motor of the problem Sırıtma
08.05.2020 15:33 # 3
starter engine of the problem :)
08.05.2020 15:33 # 4
Kemanyak
At the top of the starter is a device like a magnet that works with a magnetic field. (the name is said strangely in the industry shame) If the alternator is not mistaken. Since that device is stuck, the starter motor hangs when it gets very hot or in cold conditions. You can change that device or get rid of the problem by handing it over to a skilled craftsman. The best possibility is that the spring in the spring system that retracts the gear will change (almost free).
08.05.2020 15:33 # 5
kaan__
Coal can also
08.05.2020 15:33 # 6
Starter motor is being built, yes, don't buy a new one ...
08.05.2020 15:33 # 7
muntehaozen
I apologize to me later on. I had such a problem in the service, when they connected the pc, they said the catalyst, how true? I could not make any sense.
And can I get the catalyst cleaning around 600 TL in Ankara industry?
08.05.2020 15:33 # 8
trouble from mars engine gozukuyo
08.05.2020 15:33 # 9
Kemanyak
[QUOTE = muntehaozen] I apologize to me later on. I had such a problem in the service. When they connected the pc, they said that the catalyst is true, how accurate is it?
It doesn't have anything to do with the fault you're telling Sırıtma I can't say anything about your cleaning, I don't know how they clean it. But the breakdown you told me was doing it in winter. What is the alternator manager?
08.05.2020 15:33 # 10
I wonder if you are doing much mars ?????????????????????????
Because if you do too much mars after the engine starts, the flywheel will freeze the mars sprocket very quickly and it will make a sound. Do you try to keep it a little shorter ??? Because normally it will not take 1s for the engine to start :))
It works like print ...........
08.05.2020 15:33 # 11
werty
can make from coals
08.05.2020 15:33 # 12
trtolgi
why is my friend marsa 1-2s pressed down? press and release. If you keep pressed, that sound will sound. i think you have damaged the mars engine.
08.05.2020 15:33 # 13
muntehaozen
[QUOTE = CeCoLi] I wonder if you're doing too much mars ?????????????????????????
I work with the starter and take my hand, but I hear that voice
