Anrifriz Information
08.05.2020 17:58 # 1
yenice
First of all greetings. As you know, the weather has been cold for a few days, I started to feel different when I started the car in the morning and I came to mind first antifreeze. I felt a difference in study and sound. I have not done antifreeze control for 1 year. how often do we need to check the antifreeze?
08.05.2020 17:58 # 2
TuNeR_32
A complete cleaning and change is required for 2 years.
08.05.2020 17:58 # 3
burglar08
If the antifreeze you are using is red or pink, it will give you 5 years / 150 thousand km of life. Antifreeze prevents the attitude of rust and lime, so that you do not have a question mark in mind, it becomes moldy and rust.
By the way, I do not take into account the direction of water loss, since you have not checked it for 1 year, I guess there is no problem
08.05.2020 17:58 # 4
gogly35
There is no reduction in the amount of water in the vehicle, but it seems that there is not much antifreeze in it, can I drain the water antifreeze mixture with my own means and refill the antifreeze or do I need service?
08.05.2020 17:58 # 5
burglar08
If you haven't added, the antifreeze is not going to fly away :) You change it yourself, yes, but you have to make sure that the air is taken. In addition, you do not have to deal with yourself, they make free changes in places where you antifreeze
08.05.2020 17:58 # 6
gogly35
It takes about 2 months to get the vehicle. The liquid level is normal but it seems that there is not much antifreeze in it.
08.05.2020 17:58 # 7
friends my advice to you do not put the antifreeze naive. I had my red antifreeze available yesterday. I had it last year, it was 1 year. and pure antifreeze was placed without reconstitution.
yesterday's measurement was -20 degrees.
We pulled some of the
with vacuum hose. We added a half liter of pure water on it (not tap water; a liter of pure water sold).
measurement result -55 degrees.
be an antifreeze and mix the water in half. < / div> maverick 2013-10-07 00:25:55
08.05.2020 17:58 # 8
tellotello
[QUOTE = gogly35] It takes about 2 months since the liquid level is normal but it seems that there is not much antifreeze in it, I change it outside now [/ QUOTE] How is the color of the water? You may not understand only by observation, so let the master measure when you go. If you wear it too, let it drain all the water and fill it with a mixture of water + antifreeze. I hope you will be satisfied using it. For friends who may need; Freezing information of antifreeze and water to be added to the system is as follows: Volumetric Mixing Rate Freezing Temperature 100% Water 0 ° C 90% Water + 10% Glycol Mixture -3 ° C 80% Water + 20% Glycol Mixture -8 ° C 70% Water + 30% Glycol Mixture -16 ° C 60% Water + 40% Glycol Mixture -25 ° C 50% Water + 50% Glycol Mixture -37 ° C 40% Water + 60% Glycol Mixture - 50 ° C 30% Water + 70% Glycol Mixture Case <-50 ° C 20% Water + 80% Glycol Mixture Case -45 ° C 10% Water + 90% Glycol Mixture Case -28 ° C 100% Glycol Mixture ie only antifreeze -12
08.05.2020 17:58 # 9
gogly35
it seems that there is not much antifreeze in the color of the water, so there is no color, so it was stuck in my mind.
08.05.2020 17:58 # 10
yenice
I took a measurement today and there was no antifreeze.
2 liters of antifreeze and 2 liters of water. I just looked and added 1 liter. I will check again tomorrow evening. 3 liter antifreeze prices were around 15 - 20 lira. 15 lira workmanship obviously came a little too much :) Dear masters, then they talk about cutting jobs :) It is a shame to take 15 lira for antifreeze workmanship while it is taken 50 lira for periodic maintenance work :) Anyway, what do we do next? :)
