Another signal problem is from me.
08.05.2020 14:17 # 1
Psh
My right rear signal sometimes doesn't work. The first time I went to the electrician. The signal bulb was intact. We reworked the entire cable line from the steering wheel to the signal together, we did not find any problems. The interesting thing is that when I turned on the rear wiper water, the problem disappeared. He repeated it 2 more times and when I turned on the rear wiper water, the problem disappeared again. I will say from the arm, but separate arms to wipe with the signal. What can I do about this, I wanted to get some ideas from you.
08.05.2020 14:17 # 2
okankrgz
What is your vehicle? 106-206 etc ...
08.05.2020 14:17 # 3
muhlisoz
I have also had the same problem with this problem. I use 206 xt according to my head, sometimes it works, sometimes it doesn't work, I went to the electrician. The bulbs are solid ???? warsa who knows somebody tell me walla i can not find why i am not wondering why ... muhlisoz 2010-06-22 15:39:27
08.05.2020 14:17 # 4
Melih
my left stop at 206 xt sometimes does not work according to the head
08.05.2020 14:17 # 5
GokhaN
it may be a socket or as I heard from a friend, it doesn't work because it makes a chassis sometimes the stops are according to the head
08.05.2020 14:17 # 6
Psh
My problematic vehicle is the 2005 model (which is a strange half 2005 half 2006) 307 look 1.6 petrol
08.05.2020 14:17 # 7
deniz_206
In 307s, the illness stop lamp is not lit in the back right or left at 307 every time I see it.
08.05.2020 14:17 # 8
vbmaster
I either agree or my right signal is blinking once every second, for example, now it goes out every half a second, then the duel goes back, does it have a snap fast fast chassis?
08.05.2020 14:17 # 9
deniz_206
[QUOTE = vbmaster] I either agree or my right signal is blinking once every second, for example, now it goes out every half a second, then the duel is back distorted. [/ QUOTE]
The front or rear signal bulb has exploded, check one of them, make a quick sound and snap.
08.05.2020 14:17 # 10
okankrgz
When you turn on the signal, it is more likely than it should be, or the signal, the stop bulbs do not light up, the slot where the headlight bulbs sit and the metal part of the bulb become moldy and rust over time. Disassemble the bulb and clean the socket part, bulb metel part with rust, mildew solvent, dry and assemble it. If there is still a problem, there is a broken cable in one of the socket bottom.
08.05.2020 14:17 # 11
FIRAT.75
You have to ask the master Efe or Haşim evening dress.
08.05.2020 14:17 # 12
muhlisoz
sensible
08.05.2020 14:17 # 13
okankrgz
I know it happened to me, when I gave the right signal, there were a series of popping sounds on the front console, but when I looked from the outside, the signal would not light up, then my left signal was active, and when I pressed the fire or lit a fog, the necessary bulbs would not light up, and I did the operations I removed and explained now, thank God ... If you want, if you do not get a result of an experiment, you will go to your electrician. thanks
08.05.2020 14:17 # 14
okankrgz
By the way, when I asked my service, he said that the signal is from his arm, and the cost was a little salty, too :)
08.05.2020 14:17 # 15
vbmaster
No, now the service has given me a price of 1850 lira for the problem I dealt with 75 lira Ankara ABC Peugeot :) Göral also said 1500 :)
08.05.2020 14:17 # 16
Ougus
vehicle 106 QS;
Guys, I hosed the subject a little bit but how do you solve the problem with this right-left signal?
According to my left signal head, it sometimes responds as fast as a snap. The headlight bulb does not light up in this case, it works fast in accordance with the sound in my bulb.
It often starts when I drive the car for more than 10 minutes.
08.05.2020 14:17 # 17
[QUOTE = Ougus]
vehicle 106 QS;
Hello,
First of all, you need to introduce yourself to the rules of the forum within the information in the LET'S KNOW OUR MEMBERS link.
The situation you're talking about is happening because the lamp in your ten headlights is not lit. Since this happens occasionally, you need to take a look at the bulb's socket and connecting cables.
08.05.2020 14:17 # 18
MemoTech
In another car, that incandescent part in the signal bulb was broken, that is, the bulb was cut off and when it vibrates or shakes, if it is in contact, it continues that way, if the signal did not touch immediately, the other signal was throwing fast. It was difficult to detect :)))
08.05.2020 14:17 # 19
Ougus
[QUOTE = MemoTech] In another car, that incandescent part in the signal bulb was broken, so if the bulb was cut and vibrated or shake, it continues that way, if the signal didn't touch instantly, the other signal was throwing fast. It was difficult to detect:))) [/ QUOTE]
Hi, I am a former member, I have already introduced myself, but it has been deleted for a long time, perhaps because I haven't entered the site.
