Annual Maintenance
08.05.2020 16:48 # 1
rhcpeppers
Friends, I will put the vehicle into maintenance, I have no price information. Shall I handle my service out? How many dollars will I go in. Could you write what needs to be changed and done separately with their fees? & Nbsp;
08.05.2020 16:48 # 2
metin
If the vehicle is gasoline, & nbsp;
I do not know if there is oil, oil filter, pollen filter, but if there is a petrol filter, it is okay when the air filter is changed. & Nbsp;
It is enough to control brake oil, disc and pads and control the steering oil in
. & nbsp;
About 100-120 TL you can handle 10,000 maintenance cycles.
08.05.2020 16:48 # 3
rhcpeppers
100-120? I know a lot more. & Nbsp; gasoline vehicle + lpg available lpgnin maintenance
08.05.2020 16:48 # 4
sansasyon61
100-120 but if the problem occurs in the disc and pads 250 goes to 300:))
08.05.2020 16:48 # 5
rhcpeppers
Let me not go;) How much will it cost if I have pejo in the service?
08.05.2020 16:48 # 6
GiTaRRa
400 to 1.000 review hojam..if you don't know what to change wherever you go, they will take care of it :) this is when you don't know my promises to be taken. knowing what to change ... GiTaRRa 2012-05-26 00:51:03
08.05.2020 16:48 # 7
rhcpeppers
let's go so let's go & nbsp;
08.05.2020 16:48 # 8
reality59
I have the 2004 model HDI XR, how much will they charge if I lose it in 131,000 km of maintenance? (DIESEL) reality59 2012-05-26 02:16:15
08.05.2020 16:48 # 9
sahin-peugeot
[QUOTE = GiTaRRa] 400 to 1,000 get it out, hod..If you don't know what to change wherever you go, they will get it. / FONT> [/ QUOTE]
yes, malicious tradesmen say this to you they change the parts that will not change, including some authorized services, so whether a reliable service, all filters and
oil change in maintenance, change the pads and discs if necessary, the rear discs do not wear as much as they prevent. If there is no metal sound or the problem of holding down, it means that it is unfinished, of course, nothing can be said without checking, besides, the charging belt and its bearings are checked and the sound in the bearings If there is & nbsp; it is changed if necessary & nbsp; I recommend you to change the belt 20 lira something, I recommend you to change the life of the belt for 5 years, or I recommend you change every 80,000 km of the belt. > & nbsp;
only if we consider it as maintenance parts, & nbsp; holds for 120-150tl.
08.05.2020 16:48 # 10
sahin-peugeot
[QUOTE = reality59] I have the 2004 model HDI XR, how much will they charge if I dismantle it in 131,000 km? (DIESEL) [/ QUOTE]
& nbsp;
parts diesel filter and motoy they keep the original 155 TL including oil & nbsp; they take around 30-40 TL for workmanship
08.05.2020 16:48 # 11
ozinyo
Hello
2008 model 207 cc & nbsp; I need 60000 maintenance for my dyn 1.6 vehicle. What needs to be done in this care and what are their approximate costs?
08.05.2020 16:48 # 12
metin
[QUOTE = rhcpeppers] let's not go;) how much would it cost if I had the pejo in the service [/ QUOTE]
When I asked the last service, they gave a price of 350 TL in the last spring & nbsp;
08.05.2020 16:48 # 13
alp2525
Ardeş, if you ask me, go to the service and do not pay any extra money outside of it. Show your car to a competent master of your job. Get your list. Get your order from Şahin Pejo. Let me give you an example such as the service is just 200 TL for the right-left swing change of my 307 vehicle. oil change
3-timing and recirculation change
4-antifreeze change
5-hydraulic oil change
6-steering pump oil change
7-front bend iron tire change
8-right-left swing change
9-rear axle bushings change
10-painting of calipers :)
11-replacing spark plugs
12-changing gas filter
13-left tie rod replacement
14 - cleaning the engine with spray & nbsp;
all of them are crafted 200 TL, and the staff that I call the brain of the pejo service is apart from robbing the service man who has opened his own business Do not do anything, it is your choice ..
08.05.2020 16:48 # 14
alp2525
There is also a v-belt change, besides these, maybe there are a few more things that I don't think of.
08.05.2020 16:48 # 15
fatih.ctk
trigerin & nbsp; you said the lifetime is 5 years. There are deficiencies, so what do I need to change from the most important parts? I would appreciate it if you write & nbsp; oil, trigeri?
