Annoying sounds from the doors
08.05.2020 15:16 # 1
alisuat
Greetings,
What kind of precautions can we take against the loud sounds like loudspeaker bursting or friction?
08.05.2020 15:16 # 2
serkan24577
Hello, I have a strong sound in me, but it does not make any sound through the doors, only sound from the trunk is exaggerated, and I pulled the luggage lock back a little but in vain, the setting has escaped again :) You are using my original speakers
08.05.2020 15:16 # 3
I Can Say It Is The Traditional Disease Of Peugeot. I Personally Discovered A Material.
Self Adhesive Plastic Sheet Called Sound Insulation
I am thinking of laying on the doors of my own vehicle and also on my luggage in the near future.
I have also researched the price of 50x50 cm Single Plate Price is 9 TL, but at least 10 plates should be purchased.
I don't think it will be possible to get rid of these other kinds of sounds.
the albaydemirc 2011-05-11 23:53:10
08.05.2020 15:16 # 4
The only solution is the bitüself application. I will do it soon and share it with you.
respects
08.05.2020 15:16 # 5
Mr. Colonel, is the plastic sheet pitch you called? Heated and glued with slugs?
08.05.2020 15:16 # 6
serkan24577
I'm really sick of it, it comes to the trunk, let it go.
08.05.2020 15:16 # 7
These materials are mentioned in the Peugeot Service Box. There are even sound-disconnectors, silicones, sheets. Take a look if you want. After entering your chassis number, click "Group / Subgroup" from the page that comes after clicking "Products for professionals" from the bottom right menu. Then "Bodywork", then "SEALING / SOUND INSULATION". Below it lists all the materials that can be used. You can examine them one by one with photos.
08.05.2020 15:16 # 8
metin
[QUOTE = koliva] These materials are mentioned in the Peugeot Service Box. There are even sound-disconnectors, silicones, sheets. Take a look if you want. After entering your chassis number, click "Group / Subgroup" from the page that comes after clicking "Products for professionals" from the bottom right menu. Then "Bodywork", then "SEALING / SOUND INSULATION". Below it lists all the materials that can be used. You can examine them one by one with photos.
Alkış
08.05.2020 15:16 # 9
[QUOTE = pugti] Colonel, is the plastic sheet pitch you called? heated and glued with slugs? [/ QUOTE]
A kind of bitumen sheet sticks in rough but this material I mentioned is self-adhesive ...
If desired, it becomes an effective solution in roughness.
the albaydemirc 2011-04-16 09:31:33
08.05.2020 15:16 # 10
voodoo
the only solution should be to reduce the head :) hard work is a little brother because it destroys a sound, the second one comes, the high vibration in the vehicle, I think it will always find the fuel to click.
08.05.2020 15:16 # 11
[QUOTE = voodoo] the only solution should be to reduce the head :) hard work is a little brother, destroy a sound because the second one comes, the high vibration in the vehicle, always find the click to get the bio .. easy to come [/ QUOTE]
Thumbs Up
But you don't hate BASS, you hate music playing officially
08.05.2020 15:16 # 12
mdincer34
When I hit the bass in 307, there was a noise coming from the rear trunk. He was interrupted.
But there are sounds coming from the windshields.
08.05.2020 15:16 # 13
sercinho
[QUOTE = albaydemircan] I Can Say It Is The Traditional Disease Of Peutos I Personally Discovered A Material.
[/ QUOTE Colonel. Can you take a photo of this and put it in there. I wonder where we can find it. I want to do it.
08.05.2020 15:16 # 14
alisuat
I do not have a trunk, but there are jbl on the front doors quality speaker, but even when the volume is at 20 out of 62, there is a sizzle.
08.05.2020 15:16 # 15
tigerland
While bass is striking, sound comes from the plastic parts on the door. from the plastic laths on the doors, the black plastic parts in the rear trunk of the rear trunk, these will vibrate to you :) I think it is necessary to fasten the plates and laths tightly.
08.05.2020 15:16 # 16
Friends, I had the same problem, and I bought the big sponges, which were found in lots and cheaply in the markets, and filled them with compression. Believe me, there is nothing left for the voice. Sırıtma
08.05.2020 15:16 # 17
alisuat
[QUOTE = erhanomer] Guys, I had the same problem, and I bought the doors from the big sponges, which are available in lots and inexpensively at the grocery stores, and filled them with compression. Believe me, there is nothing left for the voice. Sırıtma [/ QUOTE]
How do you remove the outer part of the door and squeeze all over me?
08.05.2020 15:16 # 18
motoberk
Yes, I was wondering how sponge now.
I thought of putting glass wool and then I covered the inner and outer metal sheets of the door with a 5mm sponge in order to make the movement of the glass mechanism difficult.
08.05.2020 15:16 # 19
alisuat
yes, let's take this up one step. As the door with the speaker in the 307s was sizzling, the buzz was reduced when I pushed the socket with the foot on the top of the loudspeaker and the clamp was pushing the slot where the speaker was, so something was loose but I couldn't solve it.
08.05.2020 15:16 # 20
boranaydogmus
I really wondered what kind of application is this? Could you explain a little? Everyone complains about this and I am looking for a solution for a long time.
Page : / 2
