Annoying problems in my car
08.05.2020 20:22 # 1
Sefa0506
Hello everyone, I had a 2006 2005 diesel vehicle at 162,000 km, I recently opened the subject, thank goodness about the turbo lubrication hose, but other problems have started to appear. It goes out again, I had to remove the battery terminals of the vehicle and the clock had been reset, and then it happened after this malfunction lamp events. Thank you everyone in advance, friends.
08.05.2020 20:22 # 2
it may be filling the life of the battery or like a charger, you will still look at a malfunction code. I say measure the voltage.
08.05.2020 20:22 # 3
Sefa0506
I bought the vehicle 1 month ago, the owner said the battery was old, is there a possibility of a charger? Ermm
08.05.2020 20:22 # 4
[QUOTE = Sefa0506] I bought the car 1 month ago, the owner said the battery is old. Ermm [/ QUOTE]
The problem is that when the battery is weakened like the battery, this type of error data, I think, before the battery change, the problem will probably disappear. If you have the battery installed in the place where you will install the battery, it is understood whether there is a problem. I think the problem will disappear after the battery change.
08.05.2020 20:22 # 5
Sefa0506
Thank you, Soner bey: - )
