Ankara Steering Wheel Coating Recommended
08.05.2020 18:50 # 1
fahrettin
Hello
I searched in the forum but I couldn't find any information. If it has already been opened, do not look at my defect already. As it is known in every car, it is not possible to use the steering wheel without sheath. Since I don't like the case, I am thinking of covering the steering wheel. I expect advice from those with knowledge. My steering wheel is from the model seen in the picture (no airbag). Can leather coating be done? I heard that black psoriasis can be covered, would you recommend? Finally, is there a place in Ankara that does this job well? Thanks
Pleasant forums
08.05.2020 18:50 # 2
samet206
I would not recommend psoriasis, it would be nice if you would be covered in upholsterers, but the cost is high.If you want cheap cost, neither case nor psoriasis I would definitely recommend worn out. I have been using it but it is fine, but you need to use your workmanship and spend 2 hours for this process.
08.05.2020 18:50 # 3
menajer
I bought leather with the same stitches, I sewed suruyo for two hours muthis 25 TL maloluyo
08.05.2020 18:50 # 4
eeccaa
I took it from those of the post type. You can get it for 10-20 TL. But it requires a bit of manual dexterity and a lot of patience. It is erected in 2-3 hours. If you say I don't care, you can do the same in Sasmaz for 70-80 TL. The only flaw with these is that only bagels are wrapped, but no worse. You look at the pictures on the internet. There are trimmers who insert the steering wheel and cut out the skin with their arms and cut the skin. It is as if he left the factory. But I don't think you can get it for less than 150 TL.
08.05.2020 18:50 # 5
fahrettin
Thank you for your interest. As you said, I bought stitched cases as the leather covering will be very expensive. I couldn't do very well but it looks much better now than before. I used to turn the steering wheel separately. LOL
08.05.2020 18:50 # 6
fahrettin
I uploaded the picture, albeit difficult :)
08.05.2020 18:50 # 7
okan77
This is the cover I made for a friend ... My first try ..
08.05.2020 18:50 # 8
samet206
Hodja, you have given a lot of pot due to the material, but also health.
That's my steering wheel.
samet206 2014-10-20 20:21:54
08.05.2020 18:50 # 9
menajer
There is nothing like hand labor, the health of your friends is beautiful, the new one becomes more beautiful
