Ankara
08.05.2020 19:48 # 1
pyrz
Good day, I have a problem with the gear shifts in my car, especially when I put it in first gear, I have a hard time, only if the pressure pad system changes, it will be cheaper if it enters complete maintenance.
08.05.2020 19:48 # 2
Rczzz
Like people in cars. If the problem is not solved completely, you will lose the patient. For example, if a person suffers from diabetes, if the treatment is not complete, the kidney goes. If the kidney goes, the liver goes. The last death. If the spark plug is burning in a car, the problem is in the coil. If the coil is on fire, the problem is killeritic convector, map maf sensor, high pressure pump, gasoline pump, valves and cylinder head, and the established institutions etc ... will go chained in this way.
I think it would be useless to make such a choice. If there is a problem, the problem must be solved completely. Temporarily repairing a 2 part only fixes the problem for a few months or weeks. Later, the malfunction repeats or it may disturb another part. Therefore, there may be a new malfunction. Complete the maintenance and the gearbox for a detailed review. I suggest you take it to the authorized service in Ankara. Make sure you run out of money, more money comes out of your pocket over time as there are new breakdowns. I think take root and get rid of the incident. No matter who says what, the authorized service is always safe, at least guaranteeing parts. And if you say see a to z and give instructions and tell your troubles, they will intervene accordingly. Apart from the services, some of them give 1000 TL, some of them are 500, some of them are 2500. Sometimes this is because they don't know the job, they intervene and waste you. Even if some of them know the job, they replace a few parts to fix the current fault and send you to avoid costing the customer. Since you don't solve the problem radically, your car definitely makes you spend again. Some people know the job, brother says it must change completely, but the quality of workmanship is also a problem if they do not collect the engine correctly. I think the best is the authorized service. I know that peugeot service in Ankara is already good quality Rczzz 2016-05-19 14:17:26
