angel rings
08.05.2020 16:02 # 1
TURAN61
I do not know if there was anyone else seeing the meeting, but cecoli knows that my two angel rings on the right were not burning. anyway today i went to "maslak ataturk sanay". In the second part, I went to an electronics shop on the street of the mazda service (the name of the shop is thrown with the pm who requests the name). the man said "blast or ballast" what was burnt. I said it is necessary to buy a team. We dealt with 60 TL including labor.
In the evening I came home and washed the car. one of the rings on the right has been restarted.
My question is: 1 . What is the solution for blast not burning? temptation, resistance ??
2 . maslak atatürk Is there a good electronics engineer you know in the auto industry?
note: after this operation i went to pejo service new spoiler windshield wiper set: 75 ytl, rear pejo and 307 writing 40 ytl (I came to change it, it was worn out). an angel you will understand, burned so much from an angel Nuke
08.05.2020 16:02 # 2
metin
Isn't it supposed to be lit only when the led changes, the warranty is over.
08.05.2020 16:02 # 3
mehmet1965
You can cancel the ballast and replace it with 160ohm resistor bagle, so 160ohm is easy for each month, so you have no problem.
08.05.2020 16:02 # 4
construct. your problem resolved brother
08.05.2020 16:02 # 5
TURAN61
[QUOTE = text] doesn't have to be lit only when the led changes, its warranty is over. [/ QUOTE]
the question has nothing to do with the led
08.05.2020 16:02 # 6
TURAN61
[QUOTE = mehmet1965] you can cancel the ballast and replace it with 160ohm resistor bagle, 160ohm as well as each month separately so there will be no problem [/ QUOTE]
I would like to cancel the ballast and connect 160 ohm resistor. I write the result
08.05.2020 16:02 # 7
TURAN61
[QUOTE = berkekk] construct. your problem solved brother [/ QUOTE]
God willing
08.05.2020 16:02 # 8
The angels should not have a ballast inside the leders. leds have a small circuit. I wonder if he addressed him ballast master ???
Maybe there is a problem in that circuit, the master could not find him ... Sinirli
At first glance, it came to my mind that the leds might be distorted. If the LEDs are intact, there is a problem either in their connection or in their circuits that supply them with low voltage.
the cecol 2011-08-24 01:14:55
08.05.2020 16:02 # 9
okan4037
NOW, we are giving money to angel headlights, but they are very poor quality .. I have no junyan. had it adjusted but it is solved in this way .. otherwise you need to get 1 brain every 3-5 months, which is very high cost is definitely deteriorating ...
08.05.2020 16:02 # 10
TURAN61
[QUOTE = CeCoLi] There should be no ballast inside the angels inside the LEDs. leds have a small circuit. I wonder if he addressed him ballast master ???
No karabiutu came out and a new black box was installed. circuit was not disabled. snrm is not a lens in me. fluorescent maybe?
I have water: http://www.modtantik.com.tr/tuning/3092-200-Eagle-Eyes-Peugeot-307-Black-Angel-Far.aspx
08.05.2020 16:02 # 11
TURAN61
[QUOTE = TURAN61] [QUOTE = CeCoLi] There should be no ballast outside the angels inside the angels. leds have a small circuit. I wonder if he addressed him ballast master ???
No black box came out and a new black box was installed. circuit was not disabled. snrm is not a lens in me. fluorescent maybe?
08.05.2020 16:02 # 12
According to what you wrote in the given link, the rings of it have already been fluorescent ... So can it deteriorate in fluorescence. Then it is true that the man calls ballast. Because fluorescent bulb works with ballast. I thought it was led ...
The ones on us are led. And the leds should be protected from water, so that the silicon is filled in the places where the cables come out, so that it does not get moisture. I guess they will have a longer vertebra ...
08.05.2020 16:02 # 13
TURAN61
so what is my solution? Will I cut the ballast again and depend on the resistance? or I am a flaky ballast .. I wonder if there are normal ballasts on the market? Or will I buy a brand new angel ballast kit. My skin was silent. WallWallWall
08.05.2020 16:02 # 14
Another tip. Silicone will be filled where the cables come out. Can I have a picture of you, Mr. Cem. I need to see his photo to fully understand the recipe. Behind my angels are hat-like hats instead of caps. Are you doing the transaction there.
[QUOTE = CeCoLi] According to what you wrote in the given link, the rings of it are already fluorescent ... So it can deteriorate in fluorescence. Then it is true that the man calls ballast. Because fluorescent bulb works with ballast. I thought it was led ...
08.05.2020 16:02 # 15
[QUOTE = TURAN61] so what is my solution? Will I cut the ballast again and depend on the resistance? or I am a flaky ballast .. I wonder if there are normal ballasts on the market? Or will I buy a brand new angel ballast kit. My skin was silent. WallWallWall [/ QUOTE]
My brother fluorescent lamps do not work without ballast. Friends thought it was a led and they said to wear resistance ...
You will continue on ballast again Gülme
08.05.2020 16:02 # 16
[QUOTE = Menderes] Another hint. Silicone will be filled where the cables come out. Can I have a picture of you, Mr. Cem. I need to see his photo to fully understand the recipe. Behind my angels are hat-like hats instead of caps. Are you doing the transaction there.
[/ QUOTE] [/ QUOTE]
My brother, I forgot to take a photo of the headlights. Sırıtma Let me put it in the car and he rushed. I wore Gunduz 1, so the headlights of the vehicle were different in the pictures of iftar day, like a van cat. Embarrassed
Right at Sahur, I wore it at night 2 at 1 o'clock and it's over. In addition, it was very nice in my cooking. I made a very nice job with Velcro clamps and became number 10. Then I beautifully attached and taped the cables of the ring and leds and inserted it in the plastic hose and wrapped it in the hose with a tape.
Also, if I adhere the circuits of the leds to the lower part of the headlight and fill the ends with silicon ... Because if water gets into the interior, there is a problem ...
08.05.2020 16:02 # 17
Could you take a photo of the back of the angels catering to you?
[QUOTE = CeCoLi] [QUOTE = Menderes] Another tip. Silicone will be filled where the cables come out. Can I have a picture of you, Mr. Cem. I need to see his photo to fully understand the recipe. Behind my angels are hat-like hats instead of caps. Are you doing the transaction there.
[/ QUOTE] [/ QUOTE]
