Angel my head takes water.
08.05.2020 14:59 # 1
BuRCaK
My angels took light water but only mist. No droplets, no wetness. even that light misting bother me. I opened the air vents behind it. I hope it won't be more. If it gets enough water to survive the winter, I return to the originals and wear the Angels after the silicone gets hot.
I said, "Let me ask you if there is anybody encountering this situation in this weather."
08.05.2020 14:59 # 2
erdal
In the same way, mine is steamed and gathered in the corner where full signals are generally .. and there is no droplet, just steam .. I didn't want to remove it and reconstruct it frankly .. I bought it because fk warehouse does not steam, it has been a few days more plugged but I hope it has been done .. I hope there is a solution ..
08.05.2020 14:59 # 3
As far as I know, it makes steam if it doesn't breathe ... if it does steam, if you open a hole in the cover, how would it be ???
08.05.2020 14:59 # 4
erdal
In my opinion, if it gets the opposite air, it makes steam.
08.05.2020 14:59 # 5
so if so why are there holes in headlights or fog lights ???
08.05.2020 14:59 # 6
When I searched on the internet, I read the articles that I am saying correctly. There are reasons such as no ventilation inside the headlight. If the interior is ventilated, the outside temperature will always be equivalent, therefore no mist occurs.
08.05.2020 14:59 # 7
dikhoron
ii, where do we drill holes .. if we get water from the ground, if it gets water short circuit bits what science .. I do not know. Gülme
08.05.2020 14:59 # 8
Carmania
Hole tunnel etc .. I think from the work ... how many of the work :) Open it with a heat gun and paste it again with mastic silicone. If you can, if you can, you can make it darken in the original headlights by the way :) Come on easy ..
08.05.2020 14:59 # 9
dikhoron
Where is the heat gun located .. so I feel like I can't do it myself .. maybe I do not have a heat gun: D .. Let's go to the electrician .. otherwise ..
08.05.2020 14:59 # 10
I do not think that the 3-4 mm hole will damage anybody but prefer the leak again.
08.05.2020 14:59 # 11
In addition, it is not a heat to press the headlight of the headlight. Anyone who can not be able to get skillful is a heat ...
