angel headlight problem
08.05.2020 14:13 # 1
mamuli
I'm new to sleep and I have a few questions. Unfortunately, one of the messages that started ie: I bought a Junyan brand angel headlight 206 ma. No problem with the right headlight. At this point, I will have 2 questions.
The 2nd question is, despite everything, the headlight is around 0.5 cm. So when you do not look very carefully, it is noticeable, but the print is dewam inside.
08.05.2020 14:13 # 2
BuRCaK
I was thinking about buying Angel too. I know that there are FK and Sonar users on the site. No such problem has ever been said. Is it a problem caused by Junyan? I guess the 2000 model is your vehicle. could you get it wrong by model year? How much did you get?
08.05.2020 14:13 # 3
StiFLeR
Doesn't look like a problem that may arise with brands Angel after 98
08.05.2020 14:13 # 4
mamuli
ewt angeller 98 post is no error.I did not find any other forums.
08.05.2020 14:13 # 5
Eyup Duygun
If you can make the abs motor play small, then that black pipe is flexible. But why won't the headlight sit?
08.05.2020 14:13 # 6
Ismail
I am using junyan in 307, I did not have such a problem. I think it was the model difference.
08.05.2020 14:13 # 7
fourus_06
No matter how long they sleep, some of the affordable materials in the market do not fit properly. Especially in some stops, this is the case.
