angel fara normal bulb
08.05.2020 16:38 # 1
kaderim@61
Hi friends, I am thinking of removing the xenon from angel headlights and installing normal blue or white bulbs. If you think it would happen, I would like to inform you what brand bulbs should I wear?
08.05.2020 16:38 # 2
Cmoss06
It does, but it doesn't taste xenon, of course,
08.05.2020 16:38 # 3
okan4037
You can attach your h1 bulb type of course :) & nbsp;
08.05.2020 16:38 # 4
kaderim@61
Have you ever seen a wearer or not?
08.05.2020 16:38 # 5
HUN
No lens in your vehicle? Is there only angel
08.05.2020 16:38 # 6
HUN
Is there no lens in the [QUOTE = HUN] tool? Is there only angel
Xenon does not blind the image that makes you miss with a good lens, even if you focus well with a bad lens, you will get a good view from the normal light bulb. White light bulb osram night braker blue light bulb m tech. But none of them are substitutes for xeno. < / div>
08.05.2020 16:38 # 7
Cmoss06
Already he & nbsp; Although the bulbs, which we call blue and white, are pleasant in the headlight, they do not precisely hold the place of the xenon as a heat.
08.05.2020 16:38 # 8
Cmoss06
The point where most of them are wrong is that the lenses in angel lenses on the market are not high quality lenses. There are two focal points on the lens, and the lenses are warm. Hella brand & nbsp; drop-off lenses are available, these lenses are very high quality and as a result original lenses, & nbsp; pair is around 50-60 TL
08.05.2020 16:38 # 9
kaderim@61
my headlights inpro cirf lenticular in front of the xenon hurts, vuroyo is not just like a yellow bulb, i am not happy with the headlight, can i show you the fog i'm traveling with fog, but it may be in the quality of the xenon, but is there any advice?
08.05.2020 16:38 # 10
Cmoss06
Dsotum then your headlight lens may be out of adjustment, and if your xenon bulb is 6000K and above, there is nothing to do on the wet and black ground. .
