Angel Eye and Xenon Headlight
08.05.2020 16:52 # 1
EErgul
I'm thinking of getting friends sonar or fk / depo angel eye but I want my headlights to be xenon too. but 3000 5000 8000 10000 halogen h1 h7 etc. I do not understand any of them
if you talk about them briefly, what we know is what. which one is what color. or if you count all of the light bulb types, I will have an individual knowledge by researching them. This place is a little complicated to me .. since we can make a xenon by installing a light bulb why people love it so much money to buy xenon headlights. Or are these two very different things from each other. & nbsp;
08.05.2020 16:52 # 2
The picture below may help to establish the correlation between K values and the color you will achieve.
People are giving money and changing headlights because the headlamp received has a lens. If you use a xenon lamp in the lensless headlight, you can illuminate everywhere without focusing on it, including the eyes of the corresponding driver. Because of this, it is necessary to change the headlights in order to look good and not to eat kufur.
08.05.2020 16:52 # 3
EErgul
We are not likely to find both xenon headlights with angel eyes and lenses, but I guess right? Is there any alternative I can get white light if I don't wear it? this H1 h7 h3 event comes in here I guess & nbsp;
08.05.2020 16:52 # 4
xpyhre
When you get an angel headlight, when you use a 6000k xenon bulb, the angel headlight has a short lens inside and you can easily use the xenon light without spreading or disturbing other drivers in traffic. It is the duty of the lens. You can wear normal headlights in white bulbs and they are cheap. I showed it in the picture below.
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp;
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp;
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; ; & nbsp; & nbsp; LIGHT COLOR: WHITE (H 4 ) & nbsp;
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & Nbsp; here is another one that I use in the fog beautiful night blue shining light ..
& nbsp; & nbsp; & nbsp; & nbsp; http://otomotiv.com.tr/oto-aydinlatma-urunleri/rg-beyaz-isik-halojen-ampul-h11-12v-55w.html
xpyhre 2012-06-18 20:20:08
08.05.2020 16:52 # 5
EErgul
Thanks a lot for the information you provided. So when I get the sonar or fk angel eye, there are already lenses in the dipped headlights. I can comfortably wear a xenon bulb. and the color of the 6000k xenon bulb and the color of the h4 bulb are the same. Of course, I know the lighting will not be the same. now everything has sat in my head thanks. If I use 6000k in
headlights, it doesn't make sense to use h4 in fog. As a result, there is no lens in fog. The difference of light intensity does not arise, should they not appear? or it makes sense to use h4 in the worst headlights and fog. & nbsp;
08.05.2020 16:52 # 6
Alicilik
Sir H1-H3-H4-H7-H11, these are bulbs, don't be confused.
Original headlights of 206 between 1998-2002 use H4 type bulbs. The difference of H4 from the others is that the light, which we call long and short, is housed in the same bulb. It takes 3 feet chassis one by one. Since the vehicle is a 2004 model, if I am not mistaken, the original headlight short is using H7 long H1.
Lens angels are generally used both H7 or H1. Depending on the condition of the lens, H1 is more preferred because the bulb plate is smaller than H1, the back of the lens does not need to be very wide.
Be careful when you buy xenon H1-H3-H7-H11 all have the same bulb part, only the foot part and the table have differences. H4 is very similar to H7, just as I said. It has 3 legs.
If you are going to use lenses, cut some money and try to find lenses of brands like Hella-Bosch. Because the lenses of cheap lenses with ready-made lenses get dirty very quickly (the bulb you use has an effect on this, the ordinary bulbs are very dark). Risky cleaning and costly work come to the same account.
I use 30000K in my own vehicle (206+). It is known as pink dd among the people, but the ash is a lie 45000K pink. It is close to the blue and the night view is very nice. You understand the difference when it comes side by side with Parlement blue. It looks deep blue next to the white and yellow halogens. I will go to the lens application as well, I have no alternative to headlights, and I am going to take the lens and make it master.
08.05.2020 16:52 # 7
metin
[QUOTE = koliva] The picture below can help to establish the correlation between K values and the color you will achieve.
koliva I would like to add additional information to your posts, & nbsp; < / div>
As the value of Kelvin increases, its color changes, and there is a lumen value. Lumen value is the value of lighting the path. The lower the lumen value, the more clearly and beautifully illuminates its path. & Nbsp;
Therefore, as the value of kelvin increases, the lumen decreases, that is, the lighting decreases. For this reason, the best value of kelvin is 4300 kelvin. Because Fakar 4300 kelvin is yellow in color, they usually do not prefer higher ones, but since the lumen value decreases, the way of lighting decreases. & Nbsp;
08.05.2020 16:52 # 8
EErgul
[QUOTE = ScHerZo] Sir H1-H3-H4-H7-H11, these are bulbs, don't be confused. Original headlights of 206 from 1998-2002 use H4 type bulbs. The difference of H4 from the others is that the light, which we call long and short, is housed in the same bulb. It takes 3 feet chassis one by one. Since the vehicle is a 2004 model, if I am not mistaken, the original headlight short is using H7 long H1. Lens angels are usually used both H7 or H1. Depending on the condition of the lens, H1 is more preferred because the bulb plate is smaller than H1, the back of the lens does not need to be very wide. Be careful when you get xenon H1-H3-H7-H11 all have the same bulb part, only the foot part and the table have differences. H4 is very similar to H7, just like I said, it has 3 legs. If you are going to use the lens, try to find a lens for brands like Hella-Bosch. Because the lenses of cheap lenses with ready-made lenses get dirty very quickly (the bulb you use has an effect on this, the ordinary bulbs are very dark). Risky cleaning and costly work come to the same account. I use 30000K in my own vehicle (206+). It is known as pink dd among the people, but the ash is a lie 45000K pink. It is close to the blue and the night view is very nice. You understand the difference when it comes side by side with Parlement blue. It looks deep blue next to the white and yellow halogens. I will go to the lens application as well, I do not have an alternative for headlights. Thanks for the [/ QUOTE] information. sonar angel eye headlight lens is insufficient so i'm going to get it, i'm master. i also need to go into a lens operation. For now, it surpasses me, but at least I don't use xenon since I know it. There is also something like this: I use xenon in the headlight, for example, I have lenses in my head. In this case, the colors of the headlights and fog will be independent. how can we prevent this situation? If I do not use xenon in both of them, it is not a problem anyway, or if we start with the information given by my text friend, it may not catch the eye of the other person if I flash any xenon to the headlights and flash 10000k xenon to the fog. Considering that the illumination of 10.000k is very low ... EErgul2012-06-19 14:30:57
08.05.2020 16:52 # 9
Alicilik
Due to the nature of the fog, no matter what type of bulb you use, it will catch the eye of the other person.
If you can, there are lenses with special lenses for 206. I think you can use them after the sonar.
08.05.2020 16:52 # 10
EErgul
unfortunately, but still liked it.
