angel dipped beam problem ..
08.05.2020 19:54 # 1
MadTurk_
about 3 months ago I put angel headlight on my vehicle. I am very satisfied so far. When I started my car last night, the headlight sensor was on and dipped headlights did not light up. When I burn the tall, the high beam was on, the shorts were not on. I tried turning off the sensor and turning it on manually again, but it was not lit again. headlight light is on the display .. nothing like this has happened before. Since I was on the road, I did not have a chance to stop and look. why do you think it might be?
08.05.2020 19:54 # 2
Does the sensor light up manually when the sensor is off?
08.05.2020 19:54 # 3
MadTurk_
it does not light up when the sensor is turned off.
08.05.2020 19:54 # 4
Have you checked the insurance and roles.
08.05.2020 19:54 # 5
MadTurk_
I looked at the roles, no problem. Is it short or separate in insurance?
08.05.2020 19:54 # 6
Just brother, check them out.
http://public.servicebox.peugeot.com/dtt/ddb/
08.05.2020 19:54 # 7
MadTurk_
I found the insurance from the site you provided, I checked it, but they do not see any problems. are we going to go to industry now?
08.05.2020 19:54 # 8
It is important that I get electricity to dipped beams, so it is necessary that you will have to go to an auto electrician. it is necessary to check the installation.
08.05.2020 19:54 # 9
MadTurk_
My soner problem has been solved. Interestingly, both bulbs burst. The one that deceived me was the explosion of both.
