Anfi connection help
08.05.2020 19:22 # 1
Firtina61
Hello, when I bought my 206 car, the audio system cables were pulled up, I connected the amplifier, I had the bass control switch of the tape's amplifier output, 12v inputs, the bass control switch is on, but when I turn it on and off, the speakers on the doors diminish, bass is working.
08.05.2020 19:22 # 2
Firtina61
08.05.2020 19:22 # 3
Alicilik
[QUOTE = Fırtına61] [/ QUOTE]
First, this part was wrong. You converted the output channel to mono in the amp.
If you connect the channel you have separated with Catal cable to the same colored RCA in the amplifier, you will get stereo output.
But on the other side, I couldn't see the upper part, there might be a problem with the amp.
08.05.2020 19:22 # 4
Firtina61
Can you explain a little bit more?
08.05.2020 19:22 # 5
Alicilik
[QUOTE = Acquisition] [QUOTE = Fırtına61] [/ QUOTE]
4-RCA beam entering the amplifier in this photo, turn 90 degrees clockwise Wink
08.05.2020 19:22 # 6
serdaralisan
My brother said that when the control of the baath is dimmed, the sound on the front doors is going, I understand that if you are wrong, you fix the columns on the woofer channel and the woofer on the column channel, and the connection cables to the bass should have been connected to the columns on the side of the columns, and the streo amplifier also connect the press cables as in the example I will give you now (1+ , 1 -... 2 +, 2-) 4 channels, either press your amplifier plus cable plus 1 you are connecting the minus cable to minus 2, you connect the bass inputs plus plus minus minus this link provides mono input to the press you get the bass sound sweetly columns DO YOU HAVE A STROUGH KEEP CALM TWEETER SIDE ANFIETE DIRECT BINDING ANFINE VERY WARM OUTPUTS FIRST INSTALL TO CONNECT THEM
08.05.2020 19:22 # 7
serdaralisan
I FORGOT TO SAY THAT THE INSURANCE IN THE ANFIN IS 30 A PUT 25 A PUT A LOW VALUE
08.05.2020 19:22 # 8
Firtina61
[QUOTE = if you are serdarra] My brother said the sound on the front doors is going down when the control of the head is low. Connect it like (1 +, 1 -... 2 +, 2-) 4 channels or press your amplifier plus cable plus 1 you are connecting the minus cable to minus 2 you connect the bass inputs plus plus minus minus this link provides mono input to the press bass sound sweet You get the columns in a way that you are already doing a streo. CALM TWEETERS SINGLE ANFIYE POST BINDING THE ANFINE VERY WARM OUTPUTS COME BACK FORWARD
Thank you, you solved the problem as you explained the problem was resolved. You said that you did not connect the tweeters to the amplifier. I had the original column in the door and the mirror. in the trunk there is JBL 30cm bass rear pendulum places for now empty 16cm mid think room now
08.05.2020 19:22 # 9
Firtina61
[QUOTE]
Original of Anfin has 25A
08.05.2020 19:22 # 10
madblueblacksea
[QUOTE = Storm61] [QUOTE = if you are serdarra] FORGOT TO SAY I FUSE THE ANFINE 30 A PUT 25 A PUT IS NOT LOW
Original of Anfin has 25A [/ QUOTE]
Use 25 se 25. It is calculated according to the max current to be drawn by the amplifier. If you put 30, you will burn the amplifier as it will not blow the fuse in overload.
