Android Auto
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2016-)
20.12.2020 19:13 # 1
Ture
I bought 3008 a week ago. There is the Androin auto feature on the vehicle. My mobile phone is Samsun Galaxy S10 .. I got support from both Samsung and Peugeot but could not find any solution. Are there any 3008 users encountering this issue? If anyone has any information or suggestions, I would appreciate it.
21.12.2020 09:11 # 2
Welcome aboard. Unfortunately, many peugeot users experience this problem and many people do not know about the solution. One of our members was solved in the authorized service with an application on google play, but we do not know which one because he did not write, teacher, unfortunately.
21.12.2020 13:35 # 3
Ture
I will try to solve the issue. I will share it with you as I solve it. There must be a logical explanation for this job. The system works when using another Android based cell phone other than Samsung. I don't think the problem is with the vehicle. For those interested, the Car's Music system is too weak. Their speakers are low Watta and their magnets too small. For this reason, when you open the music a little, the sound becomes distorted. I'm thinking of changing front rear speakers and plugging in an amp. I'll put a Sub woofer in the spare wheel place. Thus, everything will look original from the outside. It will be done within this week, I'll share it with you when it's finished.
08.03.2021 01:23 # 4
stat
5008 I was having the same problem.
My writings on this subject can help you.
13.06.2021 12:02 # 5
tilt_y
I can't use android auto, which I used before, after resetting the phone. I'm getting the warning in the photo. No matter what I did. Has anyone encountered such an error before?
"Mirror Display Solution, mirrorlink connection cannot be established. To start Android auto, use phone settings change the default connection, then reconnect the phone."
20.08.2021 11:19 # 6
canbek
I was able to use it for a few months without any problems, then I guess it suddenly broke after the phone's own software update or the android auto application on the phone. I also tried with different cables, but unfortunately android auto does not connect, it warns like plug in a suitable usb. it's really bad that we can't find a solution
23.08.2021 22:29 # 7
MesutKorkmaz
Hello. Were you able to solve the problem? I am also having the same problem.
23.08.2021 22:34 # 8
canbek
Unfortunately, I tried different cables and failed. I deleted the Android auto app and installed it, still didn't work. iPhone works fine, but android does not work :(
27.08.2021 15:40 # 9
canbek
Hello everyone again, my phone is Huawei and as I mentioned above, while working without problems, android auto suddenly stopped connecting. The other day, I connected a brand new Samsung phone that has never been paired with a car with a direct cable to the car and android auto worked. Then, when I plugged in my own phone, it worked without any problems. Unfortunately, it is not a solution/method, but I wanted to inform you when it works this way. If you have luck with other brands of phones, if you can connect and try, maybe it will be fixed.
16.09.2021 10:06 # 10
hakanlab
I also suffer from the same issue, the original cable of my phone sometimes worked, sometimes it did not work, it does not work now. There is a problem like the cable is not original, this problem would not work at all if the problem of the multimedia is not the phone or the cable
