Analogue air conditioner floor lighting ??
08.05.2020 16:35 # 1
ad0896
Friends, I will have a question for you .. My vehicle has 307 and analog air conditioning system. The light bulb of the air conditioner, which shows the orange writings, exploded.
08.05.2020 16:35 # 2
albayman
most likely there is a led lamp. In the same way as my previous vehicle, Corsada, a lamp that illuminated the air conditioner buttons went out. opened a special service, changed the led lamp, took 15 lira. I think it would be appropriate to show it to someone who understands ...
08.05.2020 16:35 # 3
Alicilik
Sir, there is a very typical light bulb, something that is combined with the senses. Same as bulb system on the screens. I suggest you go to the service. Just take the light bulb and you will do the rest.
08.05.2020 16:35 # 4
ad0896
[QUOTE = ScHerZo] Sir, there is a very typical light bulb, something like a combination of sense. Same as bulb system on the screens. I suggest you go to the service. Just take the light bulb and you will do the rest.
08.05.2020 16:35 # 5
Alicilik
I was able to shoot this much with my cell phone. Sorry for the quality. If I am not mistaken, you will remove the panel with a 20 torque wrench. Tilt forward gently after removal. As you can see on the back, there are 3 tabs on the back panel of the screen. Turn them out. It is difficult to change the bulb because the wires of the bulb go up. To replace the most beautiful with the sense.
08.05.2020 16:35 # 6
maestro
I had the same problem, I asked for a long time, I asked, I would almost break the dial buttons in front of it & nbsp; but it would be a problem to completely disassemble the front dial, because there are wires behind it, there are wires behind the buttons that turn the fan on and off and select the place to blow the air. I also unscrewed the panel screws from the top, I removed the tape from the top, though it was a bit difficult, I removed the tape from the back where I disassembled the tape, I removed the senses from the back and changed the bulbs, the name of the lamps is the NON-DISPLAY INDICATIVE BULB. Try to turn the bulbs on both sides while removing and installing the bulbs, I tried to turn them on the opposite side, but your mind may not go in the tightening direction. The sockets with the bulbs attached are not on the back surface of the panel, below or above the photos. when you pull out the bulbs, you can easily remove them from the lamp holders. you can get the same 50 cents or something http://www.hepsiburada.com/Liste/modacar-12-w-gosterge-ampulu-dipsiz-01a111/productDetails.aspx?productId=otm01a111&categoryId=20024646# Gorsels
maestro 2012-02-09 20:24:45
08.05.2020 16:35 # 7
ad0896
It was very useful, thank you for me, but I will only ask you, is this incident the same for illuminating the road computer?
08.05.2020 16:35 # 8
Alicilik
teacher, 2 lines on the pictures. It wasted when I installed 3 lines on my vehicle.
08.05.2020 16:35 # 9
ROLAND
teacher can you sell 2 lines of screen
