Analog Air Conditioning Setting Problem
08.05.2020 21:24 # 1
alcarzer
First of all, hello. There is a problem in the analog air conditioner of my 2004 1.4 hdi xr vehicle. I have a problem that I can not make sense in the analog air conditioner. it hardens and when I push it, it pushes the right-most temperature setting to the coldest, as if the gears in it push the left side, the right side changes. Whatever I do, it always blows from there, as if it is stuck, there is very little air coming from the driver and the passenger.
08.05.2020 21:24 # 2
Karacocuk24
[QUOTE = alcarzer] Guys first hello, I just joined you.There is a problem in the analog air conditioner of my 2004 1.4 hdi xr vehicle.If I put the temperature setting on the far right to the top left, the last two left after I set where I set the temperature on the far left to the head When setting the windows to the stage, the setting becomes harder and when I force it, it places the rightmost temperature setting to the coldest, as if the gears in it are pushed to the left, and the right side changes. Whatever I do is blowing from the long ventilation of the glass, it blows from there as if it is stuck, there is very little air coming from the driver and the passenger. The wires on the back of the panel may be interlocked, take out the tape location and take a look behind
