An interesting problem ...
08.05.2020 17:01 # 1
Serkan
Yesterday, I said, let me press the car on the Aydın İzmir highway so that the car was a little painful. It came out until 170, then I took my foot off the gas until 130, then suddenly all the indicators fell to zero, the stop light came on, the abs and airbag warned, then everything returned to normal, but the airbag lights I stayed hungry, pulled over, waited a little, stopped and switched on the ignition again, immobilizer engine fault error but the car worked normally, there is no problem at all, I will go out for a return tomorrow.
08.05.2020 17:01 # 2
_semihk_
According to the head of the air bag light is burning in me .. when there is no problem: S I think this is chronic
08.05.2020 17:01 # 3
berk2309
It is not possible to connect to the computer without connecting it to the back of the malfunction.
08.05.2020 17:01 # 4
Serkan
Today, I traveled around 100 km in Izmir, no problem, tomorrow, I will go out to the road and when I go to Istanbul, let me connect the computer
08.05.2020 17:01 # 5
fatihgg
Is there a xenon system in the vehicle, were the headlights hungry? I also had a shortage of zeroing down the indicator.
08.05.2020 17:01 # 6
xxxxxxxxxo
There is a problem of vehicle charging. Battery or charging dynamo.
08.05.2020 17:01 # 7
Serkan
There is no xenon headlight in the vehicle, it was off in the headlights, I need to get out of the way today.
08.05.2020 17:01 # 8
blinddark
I had the same problem when I bought my previous car & nbsp; As the car opeldi pushed between the gears between the gears, the tar hands dropped to zero. When this system breaks down, when the electricity production increases, the vehicles should look at the charging dynamo to secure themselves.
08.05.2020 17:01 # 9
Serkan
[QUOTE = blinddark] I had the same problem when I bought my previous car & nbsp; As the car opeldi pushed between the gears between the gears, the tar hands dropped to zero. When this system breaks down, when the electricity production increases, I think the vehicles will have the power system to secure themselves. I think the charger is looking at the charger [/ QUOTE]
Let me throw myself in Istanbul without forcing ...
08.05.2020 17:01 # 10
yenice
Get well soon. I think everyone agrees from the charger. & nbsp;
08.05.2020 17:01 # 11
berk2309
If they say I change the charging dynamo, I do not change it, I think it costs 800 lira from the conjunctor and 70s a tenth & nbsp;
08.05.2020 17:01 # 12
nkre51
remove battery terminal, wait 15 minutes, plug it back in.
can be fixed
08.05.2020 17:01 # 13
Serkan
[QUOTE = nkre51] remove the battery terminal, wait 15 minutes, plug it back in.
can be improved
I have been traveling for about 200 km for 2 days, I still have no problem, I think something instant happened. reacted vehicle
08.05.2020 17:01 # 14
_pathfinder_
I think you are wrong serco05 master, the vehicle works mechanically. It is not an emotional being. You have a malfunction you know. You are carrying life or souls on 4 wheels. At least, you should connect it to the computer before going out. You panic ..
& nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; * As important as wearing a seat belt symptoms of failure *
08.05.2020 17:01 # 15
fatihgg
[QUOTE = xxxxxxxxxo] There is a problem with vehicle charging. Battery or charging dynamo is problematic. with a master and gauges.
08.05.2020 17:01 # 16
kaderim@61
brother on the eve of the eve of the eve of the day, the first day of the holiday, I would look at it all over the car. because of the low voltage coming from the battery, the vehicle started to be ridiculous because of the low voltage coming from the battery.
08.05.2020 17:01 # 17
istanbullu_3886
get well, brother, I think you better connect it to the computer
08.05.2020 17:01 # 18
Serkan
[QUOTE = istanbullu_3886] I hope you better connect it to my brother in my computer [/ QUOTE]
Thank you Turan Abi, I will appoint myself to Istanbul :))
08.05.2020 17:01 # 19
istanbullu_3886
wait, watch out
08.05.2020 17:01 # 20
GiTaRRa
If the fuse is 15, 20 is installed. I think that the fuse was blown up when it was high and it was activated again.
Page : / 2
