An interesting malfunction :))
08.05.2020 14:02 # 1
gs5165
Hi guys we have an interesting breakdown:
When driving on a road of 50 km length and on the same ground, in a slice of only 1 km, I have a hard time keeping the steering wheel as if the rim was broken, then it passes, there is no problem in the front set of the vehicle, what is the problem in torsion?
08.05.2020 14:02 # 2
hasimayaz
Frankly I didn't understand anything ??
Let me ask the questions;
1. Is it shaking every time it passes through the same route on the same route?
2. When it reaches a certain speed, vibration starts and when it reaches a certain speed, does it interrupt ?? (i.e. it vibrates between 110 and 130, but not 90 or 130?
3. 1-2 m at a random time. Is it shaking then cutting?
08.05.2020 14:02 # 3
gs5165
1. The route does not matter.
2. The speed can swing regardless of the difference.
3.Yes, it shakes at a random time but at a longer distance and passes by itself. If I leave the steering wheel, the steering wheel swings strongly to the left or right, but after a while, the probelm does not remain for 1 or 2 minutes.
08.05.2020 14:02 # 4
hasimayaz
How do you get a reaction to the pressure when the tremor starts? Can you feel the tremble on the pedal ??
08.05.2020 14:02 # 5
gs5165
it is not felt on the pedal, it feels more like it just feels in the other way, it shakes me even officially, it is quite violent like knocking beyond shaking
08.05.2020 14:02 # 6
hasimayaz
The entire front team needs to be checked. Especially shock absorber mounts, Tuesday, tie rods, spiral plate (by the way, is there a spring in the car and how many cm?
Steering gear and steering column joint are also among the possibilities.
08.05.2020 14:02 # 7
gs5165
all the front team has been checked swings, shock absorber blocks, tie rods changed 500 km ago yes there is a 3.5 spring in the car.
08.05.2020 14:02 # 8
hasimayaz
206 cars?
08.05.2020 14:02 # 9
gs5165
yes 2001 206 gti
08.05.2020 14:02 # 10
hasimayaz
Check to see if there is a lock bolt at the junction of the steering box and the shaft. Can you take the steering height adjustment to another position and try it? They make empty spaces quickly.
Are the brake discs the original disc? Is there a cooling hole?
And finally, is there any swelling of the tires on the cheek?
hasimayaz 2009-04-30 20:36:01
08.05.2020 14:02 # 11
gs5165
There is no swelling in the tires, my new teacher is a tire, but a poor quality brand achille has not been 1000 km, I hope we will take the car to paris tomorrow with the master, I hope the same thing will be with the master when my car goes to the dentist. doing :)
08.05.2020 14:02 # 12
Long Beach
[QUOTE = gs5165]
problem 90% of tires, stew of cheap meat Sırıtma
It is always useful to use (premium) brand tires for driving safety and comfort.
Inexpensive China and lower segments, in particular, are deadly hazards for Gti vehicles. Braking distance, wet road, warming, etc. like.
For example, Sava is a company of Goddyear, but it is definitely not of Goddyear quality.
