amplifier installation help
08.05.2020 14:18 # 1
syz33
May it be easy for everyone.
I want to connect the new HARWARD HR-N708 amplifier to my car with an output that says Goldmaster 4x45w in my car.
- Front doors have PIONEER TS-G 1643R 180W-16 CM speakers,
-I think to attach 2 ovals to the rear pendulum, Pioneer TS- A 6992 S 460W
-Sony XS-F6935 Speaker, 300 watts.
what do you think and i plan to do everything about it including pandizot, i add the pictures on this subject, i would be glad if you dont help.
let's 2010-07-12 16:27:11
08.05.2020 14:18 # 2
syz33
I want help with the installation of the mafi's electrical and audio connections speaker connections are insurance.
08.05.2020 14:18 # 3
H-a-d-i
your tape probably has 2 RCA outputs. but your amplifier has 4 RCA inputs. The way to make the tape with 4 outputs is to buy Y chips. here is the picture:
the single end will be attached to the tape, and the double end to the CH1 and CH2 in Low Input. that is, the white RCA cable of the tape will be connected to CH1 and CH2, and the red RCA output to CH3 and CH4. so you need 2 of these Y chips. (pair 7-8 TL)
There are already 4 speaker outputs in the amphitheater. The cable ends of the speakers will be connected to the screws under the Speaker inscription, corresponding to each cable (+) and (-).
audio cables input and output processes are finished ... in the electrical installation ...
There are 3 screws under the POWER post.
GND: the chassis, that is, the negative end. The cable to be connected to any iron parts of the vehicle will be connected to this GND end. For example, the seat belt under the rear seat can be taken from the fastening screw.
REM: The blue cable on the back of the tape will be extended and connected here. There is already 1 blue tip on the tape. this cable also turns off the amplifier when the tape is turned off, and turns on the amplifier when the tape is turned on.
BATT: (+) is the end. A fuse in the picture below will be mounted on the cable from the positive pole of the battery. it's pretty simple. then the tip coming out of the fuse will be connected to this BATT screw.
electrical connection is also completed. You can adjust the location of the fuse according to your head. they usually install the fuse somewhere next to the battery. The (+) cable from the battery should be as thick as possible. it may even be as thick as our little finger.
I tried to explain as much as I can, let my friends fix it if I am wrong, I am waiting for questions if there is a place that is not understood. Good luck with.
08.05.2020 14:18 # 4
Haci
This is the case, come on, congratulations!
EDIT (Come on): thank you Haci master, who is electronics, who am I? I just connected 3-5 wires together. You must definitely add them. If there is a lack, complete it. let's 2010-07-13 09:11:22
08.05.2020 14:18 # 5
syz33
Come on, brother, thank you I had planned some things in my head, but I was trying to make sure you added something to you and it was complete.
If I have a heavy amount of mdf in the pendulum, will I make sagging from the side supports or something, if I have a delicacy detail, this will be my last question ...
08.05.2020 14:18 # 6
H-a-d-i
I think 18 MDF is ideal. 8 is very thin. may not carry speakers.
08.05.2020 14:18 # 7
Haci
There is nothing to add, the master is well described. :) I think the rest is up to friend's dexterity ...
08.05.2020 14:18 # 8
t@lip
Hadi has put the last point on the assembly of the amphitheater, health brother in his hands and heart, this will be very useful.
08.05.2020 14:18 # 9
H-a-d-i
I will not know how the capacitor is connected, how much it is needed, is necessary and unnecessary. How happy I can be useful!
08.05.2020 14:18 # 10
vbmaster
yaw ...
08.05.2020 14:18 # 11
syz33
I forgot the war, I forgot the capacitor guess, my set will not be needed, but when I say this, I don't know what it does to the system ...
08.05.2020 14:18 # 12
vbmaster
My teacher capacitor fit actually prevents the battery from overloading. If not, it causes the lights of the vehicle (including headlights) to decrease and increase in every bass that you can see in the cars of Şahinci maganda friends :)
08.05.2020 14:18 # 13
syz33
syz33 2010-07-14 08:52:37
