Amplified + sub to the fabricated system.
08.05.2020 16:26 # 1
Can only an amp and a mid-power sub be attached to the fabricated sound system of the 307 vehicles without changing the cd player? What should be patched, what brands should be looked at?
08.05.2020 16:26 # 2
sedataksu
If the original tape has an amp output or a line output, it is necessary to look at it. If there is no, an intermediate apparatus can be connected to the amplifier at the output of the loudspeakers by lowering the gain and connecting a sub with a 1000 1200 cabin and a mono amplifier. You can look at Xetyec xi 600 and sub-cabinet with jbl cabin. In total, it costs 400-450 TL. If you say you are more suitable, you can look at jbl xetec second hand mono amp and jbl sub.
08.05.2020 16:26 # 3
bahadiryor
You cannot directly connect amps to the original tape. You need to get the converter together, the price is around 30 TL. In dönüştürücüyü & nbsp; You are connecting to the amplifier.
08.05.2020 16:26 # 4
yavuz25
[QUOTE = printing] You cannot directly connect the amplifier to the original tape. You need to get the converter together, the price is around 30 TL. In dönüştürücüyü & nbsp; You are connecting to the amplifier. [/ QUOTE] There is a problem with
audio output without converter. "Ermm"
08.05.2020 16:26 # 5
huseyinnn
Even if it is a transducer, there is a possibility that the amp or bass can be damaged. If you say budget as a bass amp, I can give you suggestions according to many brands.
08.05.2020 16:26 # 6
volkanbalik
There is an amp output on the back of your tape, so you can optimize your system by getting an appropriate amp.
