amp setting
08.05.2020 19:11 # 1
baris033
Hi everyone, I had my car 307 last week, I had a sound system, but I'm not sure if it was installed correctly.
1 double impack companet
1000 jbl woofer
jameson usa 1804
My question is that in my confirmation, there is only one amp output, 2 RCA outputs, so there are 4 RCA inputs in the amplifier, I bought a rotter cable called Y, but I did not see the element I had plugged in. I used two outputs. I will be happy if you care about the pictures where I will make the tizz setting and the settings of the woofers and the companets.
pictures
http://www.hizliresimyukle.com/images/2015/03/27/20150327_182702.jpg
http://www.hizliresimyukle.com/images/2015/03/27/20150327_182633.jpg
08.05.2020 19:11 # 2
baris033
If nobody has any idea, let me tell you how to wear this little triangle piece just behind the mirror on the door of the cardboard :)
08.05.2020 19:11 # 3
koray.turan
While removing it not to be broken
08.05.2020 19:11 # 4
nirvana666
Dude, if you get full efficiency sound from all equipment, there is no problem, but the connection seems wrong to me.
08.05.2020 19:11 # 5
oguzhan29
I wish you used y fork cable
