amp selection
08.05.2020 18:50 # 1
mertozsoy
hello good forums i wish i have 1 question for everyone i have 17cm 4 round speakers 4x240 watts pioneer, 1 single coil 1000 pioneer bass available i am looking for amps according to these 1 Kenwood KAC-M846 720W I have a sound systemist suggested me HEI mono amps I had a hard time getting all of them, so for now, I can't buy mono, I would be glad if you help me again.
08.05.2020 18:50 # 2
korkusuz202
kenwood kac 846 720 I also have it. i am listening with kenwood 16.5 component 300watt at the back kenwood 2 oval 500 watt and sony 1000 watt uninterruptedly. I do not need .mono amps.17 Use the mono bridged.
08.05.2020 18:50 # 3
mertozsoy
Will 720 watts cover them? :D
08.05.2020 18:50 # 4
korkusuz202
Don't worry about those values, let me give you an example. Jameson writes 1500 watts, but the interruption makes noise. I use 2 oval 500 2 components 300 +1000 sub.
08.05.2020 18:50 # 5
mertozsoy
wow :) less than yours, my watt maşallah :) so i hope it will not be a problem if i get it, i dont have much call this ohm i know i will take it with watts and help 1 time because i dont want to buy something wrong
08.05.2020 18:50 # 6
korkusuz202
let me add that the cabin of the subwofer is large, you get deeper bass. And this kenwood amp has this 50 hz and 200 hz setting. I found it myself :) plumbers say change the amp powerlessly .. Finally, I also say that they believe in the words of sellers or buyers, believe that words are better or worse ... they do everything to sell the product in their hand ... search and learn what you know ..
08.05.2020 18:50 # 7
mertozsoy
I'm going to ask the last question, sorry, but the features of the speakers are:
Maximum input power: 240 W
Nominal input power: 40 W
Frequency response: 30-30,000 Hz
Sensitivity: (1W / 1m) 90 dB
Woofer size: 137.0 cm
Woofer material: IMPP cone
Mounting Depth: 46 mm
subwoofer 30 cm single coil so if i buy kenwood it will not meet, will not make a problem thank you again
08.05.2020 18:50 # 8
korkusuz202
brother, now the sound system will be the first ... I do not think it will be a problem to make the cable workmanship beautiful.
08.05.2020 18:50 # 9
mertozsoy
No master, I don't think so. If I regret, I will be from the amp. No other problems. :)
08.05.2020 18:50 # 10
mertozsoy
I hope my products meet my products, I don't want anything else :)
08.05.2020 18:50 # 11
korkusuz202
For about a year, I use this amplifier, and as I wrote above, the values in me work more comfortably.
