amp cable
08.05.2020 17:47 # 1
cenqo7535
Good day guys, I want to connect an amplifier to my car, but I would be very happy if anyone with information would help.
- I will pull the cable from the battery to the amplifier +12, but how can I get the cable from the front.
Thank you very much in advance
08.05.2020 17:47 # 2
206FR
When you open the hood and look at the right or left side, you will see a place where there are bulk cables with a black plastic, but when you push it in, it is usually easy, but whichever side you insert it, it is easier to try to catch the cable with someone or yourself.
08.05.2020 17:47 # 3
BerkeKarayel
I think your vehicle 307 is very simple. Under the wiper attached to the driver's side of your vehicle, there is a top cover with a hole. Remove the cover carefully before remove it do not break the nails. When you open the cover, you will see two plugs. ,. The plug on the side is as small as the nail. The hood wire passes through the other plug, you can easily pull it out with a pair of pliers. then shine the light between the battery and the engine fuse box towards the area where that plug is located. When you pass the cable, the ratio comes directly under the wiper cable, where the plug is, then insert the cable through the hole that we opened. open the inner fuse box. push the cable around 20 cm or 30 or shine the light inside the fuse box and you will see the cable. of course, silicon around the plug that we have opened thoroughly ... and do not connect the cable to the battery until you connect the amp.
08.05.2020 17:47 # 4
cenqo7535
yes my car is 307. I will do as you say thank you very much. the only thing that scares me is that it gets water in there =)
08.05.2020 17:47 # 5
BerkeKarayel
[QUOTE = cenqo7535] yes my car is 307. I will do as you say thank you very much. the only thing that scares me is getting water in there =) [/ QUOTE]
Do not worry, nothing will happen after siliconing :))
08.05.2020 17:47 # 6
qqyyxx
I think your tool [QUOTE = BerkeKarayel] 307 is very simple. Under the wiper attached to the driver's side of your vehicle, there is a top cover with a hole. Remove the cover carefully before remove it do not break the nails. When you open the cover, you will see two plugs. ,. The plug on the side is as small as the nail. The hood wire passes through the other plug, you can easily pull it out with a pair of pliers. then shine the light between the battery and the engine fuse box towards the area where that plug is located. When you pass the cable, the ratio comes directly under the wiper cable, where the plug is, then insert the cable through the hole that we opened. open the inner fuse box. push the cable around 20 cm or 30 or shine the light inside the fuse box and you will see the cable. of course, silicon around the plug that we have opened thoroughly ... and do not connect the cable to the battery until you connect the amp ... [/ QUOTE]
When I pulled the cable, it was enough to insert the wipers and remove the plastic completely. Well, those who did not call it empty are wise.
08.05.2020 17:47 # 7
Alicilik
He helped each other: D
08.05.2020 17:47 # 8
cenqo7535
can you also help in choosing the amp?
Roadstar RDA-6040 2400W 4Ch
FORWELL FLT-4060 MOSFET OUTLET 4 CHANNEL
Ads AD8000.4 2400W 4Ch
I was unstable between these 3 and I wanted to consult you if you use it or whichever you recommend. For now, I will only be connected to the bass amplifier.
08.05.2020 17:47 # 9
Alicilik
buy one, hit the other, get 3 of them all cheap
08.05.2020 17:47 # 10
cenqo7535
which one to hit which one i hesitated?
08.05.2020 17:47 # 11
soner09
kicker take my brother or bass amp jbl 1201 e 1 series have a look back don't have 2 hands 300 blades nette
