amateurs help
08.05.2020 16:52 # 1
vettec123
friends pegeuot 206 the right front shock absorber of my car is passing through the pit, zmaan `` pull out '' sound is the shock absorber break out or is there another problem? I'm waiting for your valuable responses
08.05.2020 16:52 # 2
I couldn't get the sound out completely, but Z-rots fail first in the sound problems that occur when passing through this type of cascade. When he goes to a master, he will lift your car in the fiber and decide whether the problem is from the z-rod by shaking the z-rod with your hand to the right and left.
08.05.2020 16:52 # 3
vettec123
Excuse me, I do not understand much, is this a costly event? The metal stamp that I said to get out of it hits somebody or I say like a tambourine sound & nbsp; would it hurt to go a little like that?
08.05.2020 16:52 # 4
[QUOTE = vettec123] excuse me, I don't understand much, is this a costly event? The metal stamp that I said to get out of it hits somebody or I say like a tambourine sound & nbsp; Would it hurt to go a little like this? [/ QUOTE]
Are you likely to shoot a video of the sound? Sorry, the voice you mentioned didn't wake up a call.
08.05.2020 16:52 # 5
xpyhre
[QUOTE = vettec123] excuse me, I don't understand much, is this a costly event? The metal stamp that I said to get out of it hits somebody or I say like a tambourine sound & nbsp; Would it hurt to go a little like this? Your master can say that the looks need to change, or they can handle it. If it just doesn't change, that voice gets stuck in your head, it gets upset .. & nbsp; Z-rod is between 25 TL. & Nbsp; You give it to the master, workmanship fee is 50 TL. if it's the Z-rot issue we're talking about. subject. Reviews
08.05.2020 16:52 # 6
vbmaster
+1
08.05.2020 16:52 # 7
toga406
The plastic part of the z-rod is eroding over time, this sound is not costly due to it
get rid of the sound
08.05.2020 16:52 # 8
vettec123
bugn i went i showed the master with the bend tire said z rot :) i will change soon
08.05.2020 16:52 # 9
ahmet_ankara29
When I got into the bumps in my car, I heard a sound coming from the rear wheels and when I looked, I saw that the tire of the left shock absorber fell down, the tire on the right side is in its normal position.
08.05.2020 16:52 # 10
yigiteroglu
I have this kind of voice. I plan to show Carsamba or Thursday.
08.05.2020 16:52 # 11
yigiteroglu
The problem was on the right ten swings
08.05.2020 16:52 # 12
ozaannn
I had a similar problem, I knew that the tie rod was strong, I put it in the steering box. I'm sure the ears of random cumcu, I am sure I got stuck.
