ALPIN USA 204 COPYING PROCESS
08.05.2020 14:05 # 1
CIHANGIR_DONMEZ
FOR FRIENDS 25 CM TUBE BASS BECOMING HIGH QUALITY BISE LANGUAGE BUT DISTRIBUTED COMPATIBLE DISTRIBUTOR CUTTING TO THE BOX ON THE BUTTER TO DISTRIBUTE THE COPY TO THE CABLE TO MAKE A DISTRIBUTED COPYING TO THE COPY WITH ITS COPY. I USE A SINGLE CHANNEL OF THE 4-WAY ANFIN WATER AND NO PROBLEMS BASS CALISIO BUT THE HEAD IS BROUGHT TO BE LOADED. I SHOULD LIKE THAT IF THE PICTURES SHARE THE PICTURES "Ouch"
& nbsp;
08.05.2020 14:05 # 2
MirakGTI
It writes in the booklet of the amp, which end of which channel will be used for bridging.
There is no harm in bridging an amp which can be bridged, but there is a situation like this: How many ohms speakers can drive when the amp is operating normally, it can only last twice as loud as loudspeakers when bridged. (Some expensive amps can last the same under any condition, these are the exceptions)
So an amp that normally takes 2 ohms lasts 4 ohms when bridged. If you connect a smaller load, the amplifier may burn, fuse blown, the amplifier may overheat, the electrical cables may burn, etc. Also, even if everything is done in accordance with the book, the amp will draw more current than the norm when it is bridged, and it will get warmer, but this is not a problem.
As long as necessary conditions are met. (Wiring, ventilation, sufficient battery power, etc.)
08.05.2020 14:05 # 3
CIHANGIR_DONMEZ
[QUOTE = Mirak] It writes in the amp's booklet of which channel which end will be used for bridging.
As long as necessary conditions are met. (Wiring, ventilation, enough battery power, etc.)
08.05.2020 14:05 # 4
H-a-d-i
It will be easy to interpret if the images are a bit bigger. h_307 2009-09-18 23:18:15
08.05.2020 14:05 # 5
Here we come, we got things
08.05.2020 14:05 # 6
CIHANGIR_DONMEZ
[QUOTE = EmRaH] things we have come to come here [/ QUOTE] under my seat that is a small purchase "LOL" "LOL"
08.05.2020 14:05 # 7
hasimayaz
[QUOTE = CIHANGIR_DONMEZ] [QUOTE = EmRaH] things we have come to come here [/ QUOTE] under my seat that has been bought "LOL" "LOL" [/ QUOTE]
& nbsp;
it doesn't work with a little bits .. koyacan two presses in a row. Whatever God gave, all the malfunction lights will light up like an equalizer. :) :) .. After you take your enthusiasm, you will connect it like me and repair what you have read on the computer :)
08.05.2020 14:05 # 8
Carmania
If you tell a little about how Cihangir brother bridging is done, there is someone who knows first.
but I can still say that I know myself 4/3/2. All I know is the & nbsp; cable first channel & nbsp; & nbsp; (+) (-) plus & nbsp; In the second shoot, I know that the last channel is (+) (-) ` < / DIV>
08.05.2020 14:05 # 9
CIHANGIR_DONMEZ
[QUOTE = Carmania] Cihangir brother there are people who know the way you do the bridging.
but I can still say that I know myself 4/3/2. All I know is the & nbsp; cable first channel & nbsp; & nbsp; (+) (-) plus & nbsp; In the second shoot, I know that the last channel is (+) (-) ` < / DIV> [/ QUOTE] I DON'T LIKE DOCTOR HOWEVER, BUT I KNOW THAT ANYPHIN COPYING IS WATERING ANFIN & nbsp; (+) (-) (+) (-) IN THE OUTPUT, YOU ARE COMBINING AT THE MOST EXCLUSION OF THE EXPOSURE IN THIS ANFIDE PICTURE AS EXITS WATER WATER & nbsp; (+) (-) (-) (+) & nbsp; HOW TO COPY THIS AT THE MOST INCREASED INCREASE OR EQUIPMENT GELIO PLUSED BY A BASKET & nbsp; IF I CONSISTENT THE MINUS, BISI OLUUO TAKES TWO OUTPUT PARALLEL AND CONNECTED TO THE ANFIDEN VOICE IN THE CONNECTION
08.05.2020 14:05 # 10
CIHANGIR_DONMEZ
[QUOTE = hasimayaz] [QUOTE = CIHANGIR_DONMEZ] [QUOTE = EmRaH] the things we have come to come here [/ QUOTE] under my seat that has been bought "LOL" "LOL" [/ QUOTE]
& nbsp;
it doesn't work with a little bits .. koyacan two presses in a row. Whatever God gave, all the malfunction lights will light up like an equalizer. :) :) .. After you get the enthusiasm, you will connect it like me and fix what you have read on the computer :) "Ouch" "Ouch"
