All the lights are on !!
08.05.2020 18:25 # 1
yemre55
Friends 2005 model has 307 look, I just got it. When I run the car, the air conditioner stops after going a little more, then all the lights are on, the steering wheel gets harder, all the lights turn off, is there any idea that came to the press before? Thanks already
08.05.2020 18:25 # 2
Bugra
When I say all the lights all the lights of the indicator are on? Did you make an application afterwards like electrical xenon or something?
08.05.2020 18:25 # 3
samet206
There is a problem in the brain if there is no malfunction in the vehicle's driving or elsewhere.
samet206 2014-04-02 12:48:12
08.05.2020 18:25 # 4
yemre55
There is no plugin afterwards, just the tube. The battery was discharging two times ago, I changed the battery 2 times now, there is no problem with the battery, but all the indicator lights are on.
08.05.2020 18:25 # 5
Bugra
Well, it will shake a little, but when the battery runs out it may have damaged the brain. knowledgeable friends will help. Get well soon.
08.05.2020 18:25 # 6
ahmet_bjk
Was there such a problem before replacing the battery?
08.05.2020 18:25 # 7
berk2309
it is most likely that you will measure the battery charge, the connector on the dynamo will be out of order.
08.05.2020 18:25 # 8
Mustafa-almanya
It may be from the dynamo. It was the same of a late friend bmw, he first replaced the battery, then again the same thing (all the lights were on him). Now he has changed the charger, he says it has improved ...
08.05.2020 18:25 # 9
yemre55
Thank you friends, I will look at the master
