All Malfunction Lights Burned
08.05.2020 18:53 # 1
tolga.onal
When the friends were on the road last night, the battery light started to turn on when the car was turned off and started again, but after 200 meters it burned again, the battery was removed from the pole heads, cleaned and so on. Then when he was about to come home, the right headlight started flashing, then there was left, and then the ESP light engine light and many lights came on, the steering fluid was deactivated on the indicator, the steering has hardened, stopping and starting the car again, but after 1-2 minutes, it repeats the same thing again. My master said it might be from the Conjectors If there is no problem with the Conjector, they would like to change it from the BSI brain. I am in Konya, there is no master I know here, what kind of a path should be followed, or could the problem be from the battery 2 months ago, I installed a new battery. I would be very happy if you can give a little information if there is anything happened before.
08.05.2020 18:53 # 2
Alicilik
Did you also wash the vehicle? BSi may have taken water.
08.05.2020 18:53 # 3
tolga.onal
No, it has never been washed for 2-3 weeks, never rain or something
08.05.2020 18:53 # 4
Emask
Worn out battery probably damaged the alternator. Replace the regulator circuit of the alternator with the original, meanwhile, have the coals checked.
08.05.2020 18:53 # 5
popeyes
I recommend you look at the chassis cables.
08.05.2020 18:53 # 6
tolga.onal
The problem was not far away, I noticed that the v-belt was broken when I lifted the hood.
08.05.2020 18:53 # 7
popeyes
[QUOTE = tolga.onal] The problem was not too far away when I removed the hood, I noticed that the v-belt was broken. It was worn. Can I wear it myself for a time [/ QUOTE]
What you call the V-belt is easy to wear 20 or 30 TL but
you need tools, you can't adjust it, I think go to a master, the belt is broken, it is not a problem, you can go to the mechanic
08.05.2020 18:53 # 8
tolga.onal
thank you let me go to the nearest mechanic at the weekend then
08.05.2020 18:53 # 9
muro_60
the battery was broken in me, the same shape, all the lamps were burned, the battery has changed, you can try it with a spare battery
08.05.2020 18:53 # 10
pierson
My friends ran out of battery ... it was over before, but the master said it should be charged .. I will sell the car soon. I don't want to buy new battery. I want to charge it. Is it too harmonious to comply ... urgent help .. I can not remove the car .. how much charge the battery will take .. car problems started with the winter season ..
08.05.2020 18:53 # 11
muro_60
If you have a problem with charging, you can run out of the battery.
08.05.2020 18:53 # 12
106fb
If you are in Konya, you can go there for the Efe Peugeot special service in karatay industry.
08.05.2020 18:53 # 13
popeyes
[QUOTE = pierson] Friends the battery is over .. it was over before, but the master said it should charge .. I want to sell the car soon. I want to recharge it. for ... that the battery compatibility is very necessary .. urgent help..can't remove the vehicle .. how much charge the battery brings ..
But if you're a panicked man, the battery won't run without charging it. Don't try to fill it in vain. You will give 20 TL to the battery. If the battery is not charging, go and buy a battery.
08.05.2020 18:53 # 14
pusutr
I did not use my car in front of the house 2 days a week when I bought my car. Then I said run it and walk it did not work. Thank you, my relative is a battery minister, and the market opened a man shop and came home with a new battery with a battery tester. We installed new batteries and the problems disappeared.
But to the person I bought good.
So your friend likes to be cursed.
08.05.2020 18:53 # 15
tolga.onal
[QUOTE = 106fb] If you are in Konya, you can go there for the Efe peugeot special service in karatay industry. [/ QUOTE]
I need exactly that, I am new to konya, and I don't think I will ever go to industry again, we changed the v belt today, but broke the tensioner ball while wearing the master thanks, and I could not find this piece in konya, I could bring it from Istanbul nowhere, but we could do it by welding, but I will replace it as soon as possible. There are not many masters who understand the language of the Peutos here, especially if the subject is electricity ... Where can you describe this efe Peugeot exactly, let me go there from now on
08.05.2020 18:53 # 16
pierson
Look at the few conversations or ... I like to be cool ... let's not lower the level ... If the capacity is low, we can decrease the intelligence according to him .. I bought a battery, 175 TL.
08.05.2020 18:53 # 17
pusutr
The word here was not the person you bought the vehicle.
I have nothing to do if you were taken over.
Let's never go into capacity issue.
08.05.2020 18:53 # 18
pierson
[QUOTE = pusutr] Here was the person I bought the vehicle, not you.
08.05.2020 18:53 # 19
Orcun.Dmr
The subject is very old, but since I enter the site by phone, I cannot open a new topic, it does not. The same happened in my 307. While the air conditioner is on the road on the road, the battery lamp flashes on the display, it turns on before going 1 km, I turn off the air conditioner, the battery lamp turns off. After a while, all the lamps on the display are on, the steering is stiff, and even when the tape is turned on, even the headlights are off, it does not work again when I turn off the car. I take out the battery and follow it to the charger. After charging, I follow the battery to the vehicle again. After 1 week, the same thing happens and the battery runs out again. Do you think it is a conjunctor in my problem?
08.05.2020 18:53 # 20
Selcuk55
Exactly sister battery dynamo or conjunctor
Page : / 2
