Al4 transmission pressure sensor error
08.05.2020 21:06 # 1
ercanayman
Hi
I got the car connected to the machine these days, it is the oil pressure sensor or switch to the machine, it gave the function failure problem error. Will changing the transmission oil solve the problem?
Error message
ercanay financing 2018-12-09 17:22:37
08.05.2020 21:06 # 2
ercanayman
https://i.hizliresim.com/adavxq.jpg ercanay financing 2018-12-09 17:21:54
08.05.2020 21:06 # 3
talip206
There may be a temporary malfunction. It is necessary to wipe and make observations again. If it persists, it is most likely related to solenoid. It is possible that it is made of oil, but the condition of the oil should be checked.
08.05.2020 21:06 # 4
ercanayman
This day he still gave the same error. Shouldn't Selonoid be from evil, did he not write in the error description? Otherwise, if it was a pressure error, would it be? I don't think it was before me. I'll start with the oil change. Bidet picture also gave the error that the gear control communication was broken. I wonder what this means.
08.05.2020 21:06 # 5
probable pressure sensor may be broken, you need to disassemble and check the socket. the other problem may be the gear contactor. When was the last shifting structure changed, Hodja. Sometimes the oils that do not change for a long time lose their properties and they cannot create enough pressure. In addition, you can only change 50-60% of the oil.
06.02.2022 22:10 # 6
Hd32
Hello. I am getting the same warning in my 2005 model 307
. Does anyone know how to fix it?
