AL4 gearbox specialist Anatolian side
03.12.2021 17:36 # 1
rodrunner
Hello again. I have some problems with the AL4 gearbox and I want the advice of an experienced master who understands this gearbox on the Anatolian side. (Related to this, the radiator was changed)
-A week later, when the vehicle was on the lift, it was noticed that there was excessive lubrication in the transmission crankcase. Finally, the al4 crankcase was changed.
- The vehicle was fine for a few days, I did not have any problems. I drove for a while. div>
I want to go to an automatic transmission shop regarding this problem. Frankly, I don't want to go to any service because there are always negative comments about al4 transmissions.
By the way, my car is at 161000 km. So who knows how the transmission is?
Can you help?
06.12.2021 00:50 # 2
AdemUsta1
Hello, al4 4 speed gearbox is a gearbox that we mostly do, come to our service, let's check your gearbox together, the gearbox oil cooler explodes.
09.11.2022 09:53 # 3
rodrunner
I had no problems with the transmission oil change for about a year. But it started to give a gearbox warning again. It does this when it gets hot. The master, who had previously solved the same problem with an oil change, stated that the transmission should be opened from the checks this time. He said 40k directly for the price C onfused And write according to your own opinion He told me that I would not experience the gear fault error much in winter. I urgently need your advice.
