al4 auto problem
08.05.2020 21:04 # 1
sharky
hello friends 2012 peugeot 308 1.6vti automatic al4 I think I bought the vehicle 20 days ago, I had the maintenance of the vehicle at 32.000km.
But when it starts up in the mornings, it shifts slightly at idle, there is nothing when it warms up at 3 different times.
no loss of knock traction can cause the failure disappears when the ignition is turned off, I gave it to the master like 32 thousand vehicles, the vehicle remained on it for 1 day.
08.05.2020 21:04 # 2
talip206
Sir, it might be time to change the gearbox oil. Start by changing the oil, but go to the gearbox master, not the normal engine master. In the morning, if the jerking throat butterfly is dirty or the idling engine is dirty, this type of trouble may occur when it is cold. It needs to be cleaned and calibrated.
08.05.2020 21:04 # 3
sharky
thank you for the answer butterfly throat cleared, my spark plugs installed iridium, do I misfire from it as you said I did not change the oil eneos 5w30 I think I did not change the oil, I think I think about the solenoid change.
08.05.2020 21:04 # 4
My teacher first, if you learned the fault codes, it would be better to give an idea. But after maintenance it is a separate situation. engine oil is not a service problem. I need a lot of iridium spark plugs, frankly, does the car have lpg by the way? otherwise my gasoline
08.05.2020 21:04 # 5
sharky
I use the tool on gasoline, no lpg
08.05.2020 21:04 # 6
I have an electrovan, my teacher.
08.05.2020 21:04 # 7
ercanayman
Hello my teacher.
I have that same problem. When I run for the first time in the morning, I get the gear error when it goes a while. The problem goes away when the ignition is turned off and on. I will be able to deal with the gearbox, but I have to find a good master around Beylikdüzü. Do they change the gearbox oil during the solenoid change?
08.05.2020 21:04 # 8
talip206
[QUOTE = ercanayman] hello teacher.
Yes, when the solenoid changes, the gearbox oil also changes.
08.05.2020 21:04 # 9
ercanayman
Hi
I got the car connected to the machine these days, it is the oil pressure sensor or switch to the machine, it gave the function failure problem error. Will changing the transmission oil solve the problem?
