airbag-seat belt fault and other problems
08.05.2020 20:41 # 1
sosyolog_56
Friends good forums. I bought my 2006 model 307 1.6 comfort technopackage car a week ago and joined the peugeot family. I want to express a few problems about my vehicle. I also tried to find solutions to old topics in the forum. now the first problem in my vehicle is the airbag and seat belt fault. how can i fix this problem. The second one is that when I downshift while driving, the engine brake knocks the car or at that moment there is a tough die from behind. this does not happen continuously, but when it does, it gets demoralized. Another problem is that I have a trip computer and I activate the parcking assistance by clicking on it, but when I put it in any reverse gear, the sound, etc. I could not hear. Another one is there is a window shutter on my car. If there is, I try to do it like every vehicle, but it seems like a break happened again. my penultimate problem is steering. very rarely enough to use both hands to rotate. then it softens again, it doesn't always happen. I wonder what could be the reason. Is the model with the rear-view mirrors closed in my vehicle. Because there is a mirror closing key, it goes down and I did not see the mirrors moving when I did it alone. I would like to thank the friends who will provide help-suggestion solutions in advance. good forums
08.05.2020 20:41 # 2
First of all, welcome to us. I wish you to use your vehicle without any accident, good luck. There may be two reasons for the airbag problem, a com2000 headlight signal arm, namely the airbag wrap, the second one, the underarm sockets. The cost varies between 250 and 1000 TL depending on the situation. It may be due to possible engine or gearboxes coming into the engine when it is loaded. If the vehicle is parked, it means that if the vehicle is parked, the parking sensor brain is defective or if one or more of the parking sensors are broken. You can close the windows from the original remote control. Long press the door closing button, if it is not closing, it is necessary to re-code the windows. I have to look at the chassis whether it is a folding mirror or not. If the glass opening button may have malfunctioned, they may have replaced it with a folding mirror feature. It may not have a folding mirror feature. Your steering pump has started to malfunction, and its electronic circuits have oxidization and take off from time to time.
08.05.2020 20:41 # 3
sosyolog_56
first of all thank you for your interest. How much do you think the total cost of all this is said, hodja. chassis no.xxxxxxxx586910 now I don't know if the parking assistant and the folding mirror are in this chassis. they only have features. Most of the airbag belt fault warnings were in the 307s. would it be a problem if it was this way? thanks. sonerkyl 2017-12-19 12:21:33
08.05.2020 20:41 # 4
sosyolog_56
I think the sensors in the rear bumpers will be 4-5 or not. if it's not hidden, of course.
08.05.2020 20:41 # 5
You are welcome, my teacher will be visible in the rear bumpers, but in the techno packages, the parking sensor must be standard if they have not replaced the rear bumper. teacher, it is hard to say anything exact about the cost, a good master is poetry, it is difficult, even we had a member, he was going to a diarrhea in your city. The average steering repair is between 200-400 TL, of course you will find a master who understands it. One of our members who passed the airbag was an important teacher. others are not too much trouble. Please send the chassis number presentation privately from the private.
08.05.2020 20:41 # 6
08.05.2020 20:41 # 7
sosyolog_56
I understand teacher. When I bought the car, I put it into two places. no changes came out. I could not see such sensor housing and hole in the rear bumpers. Thanks for your warnings about the chassis. Let's see there is a master we know the tool here. He worked in the reno service for nearly 20 years, then opened his own service, I will understand the pejodan, he said. let's see. I sent the vehicle, front, back team etc. we will learn what's wrong. my expectation is to handle it with little cost. Thanks again, teacher.
08.05.2020 20:41 # 8
sosyolog_56
I think the cables have changed because of the oxidation of the seat belt warning in the underarm sockets. The tough sound that came with the engine brake was that the engine mount was split into 2-3 parts, and its replacement was made, thank goodness for now. There was no folding mirror motor in my vehicle. Also, although the parking assistant was on the trip computer and technopack, it was not standard. the master said to me that the shock absorber upper wedge, 2 rod rods and the rear shock absorber replacement can be done, although it is not necessary to change it very urgently. I leave the shock absorbers after a month or two. I have approved the exchange of other parts. in addition ta. I am thinking of replacing AYD rods, tie rods and tie rods for two front sets. Originals are expensive, I opened a new subject which sub-industry brands die closer to the original. There was a steering wheel. I couldn't make him look. The master electric motor may have been oxidized from moisture, or the hydraulic oil hose may be clogged, it may have been occasional. Thank you for your help and ideas.
08.05.2020 20:41 # 9
I'm glad some of your problems are fixed. The shock absorbers are not in a hurry, as you say, even if they are not bad in spring. The steering problem is probably as the master says on the electronic card. undercarriage definitely do not buy light, they come off quickly. I gave information on the other subject you have already opened.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
