airbag problem please help
08.05.2020 15:22 # 1
GiTaRRa
your friends, the airbag light is blinking, they couldn't get it, do you think?
08.05.2020 15:22 # 2
I don't think the airbag has anything to do with the inspection. I may know wrongly, but there are many airless cars, and they are examined.
08.05.2020 15:22 # 3
ADM
look at the buckle of the safety belt buckle
08.05.2020 15:22 # 4
[QUOTE = koliva] I don't think the inspection is related to airbag. I may know wrongly, but there are many airless cars, and they are examined. [/ QUOTE]
Is there anything to do with my brother?
The vehicle with an airbag should not burn the airbag fault. logic is water. If a vehicle has an airbag from the original it will be in operation.
We had the same catalytic converter in the same way. When they put it in, they do not pass ...
08.05.2020 15:22 # 5
[QUOTE = cecol of]
I wrote executing mind knowing the law in Turkey. Of course, it should not burn, but I do not think they will look. If I look at them especially in the procedure they apply, I will have learned it too.
08.05.2020 15:22 # 6
metin
The purpose of the koliva examiners is not passing if there are things like malfunction, fault, etc. that will threaten your life safety. For this reason, the burning of the lamp of the airbags is not examined, considering it to be defective.
08.05.2020 15:22 # 7
Burning out any lamp on the instrument panel indicates a problem with the vehicle and I don't think they will spend much (unless it is overlooked)
08.05.2020 15:22 # 8
hhuzun
This happened to me when I was cleaning the car, the socket under the seat came out, I went to the friend, I connected it to the computer, he said which one was caused, and then I plug it in again.
08.05.2020 15:22 # 9
Muhammet CAKIR
Take out when the seat moves. Move the cables under the seat with your hand. then turn the ignition off and on. If it is cut, there is a break in the cables leading to the suction belt.
08.05.2020 15:22 # 10
VEDATDINC
The same problem is going on from com2000. VEDATDINC 2011-05-02 17:58:56
08.05.2020 15:22 # 11
eren8er
I went to the examination last week..airbag lamp directly next to the lamp did not pose any problem .. i know i may not be the same everywhere ..
08.05.2020 15:22 # 12
azdek
I think they will not pass the vehicle with Airbag malfunction.
08.05.2020 15:22 # 13
GiTaRRa
I do not know, napcam I do not know, I can not find the machine. The service will take care, but they said that we can do at least 4 days after the crowded dior service is limited now.
08.05.2020 15:22 # 14
eren8er
how am I done? I mean I have to be thankful ..
08.05.2020 15:22 # 15
eren8er
my friend, you can go to the examination, if you have any problems, you can go again without paying money. I ordered .angel headlight if my inspection will be finished on friday .. fortunately they did not say anything ..airbag lamp.
08.05.2020 15:22 # 16
kaan__
If the service says 4 days, if it is stuck in your head, go to the master, there is a device, he does it
08.05.2020 15:22 # 17
monur
The airbag lamp was burning from time to time for 1.5 months. Then I got the computer connected to the service, the right passenger seat trigger failed, the problem came out of the sockets. They sprayed the sockets.
08.05.2020 15:22 # 18
Get well soon
the pugt 2011-05-03 09:39:34
08.05.2020 15:22 # 19
qentr
There are 99 "106 gti ... my momo has always been on fire since I installed the steering wheel: D and it went through the inspection, but they had a slight defect because the steering wheel is not original ... under the steering wheel, by inserting a socket in the airbag cables or by inserting or putting out the resistor. I did not do it because I did not see ... I say try your luck ...
08.05.2020 15:22 # 20
ose
mine is blinking too. I did not investigate the socket or something, they tried to connect it to the PC in vain service. I have already noticed that when I give a signal, it turns on when I turn left and it turns on. What will happen in these com 2000s, all pugs are the same problem. The French engineers arranged so that there is no pejo that com 2000 does not fail. You are asking for the price of 700 TL, they will not even give you half price. If we say let's repair it, you can not reach that piece of paper (reel) that is making contact with it.
Page : / 2
