Airbag light Warning !!
08.05.2020 17:05 # 1
06OzGuR06
Hello everyone,
While driving on the road today, the airbag lamp came on suddenly. He warned him. I pulled the driver's seat back the other day quickly. I thought it might be due to it. Sockets under the seat I already have 2 sockets. 1 of them have a seat belt warning warning, the other one is a brown socket airbag socket, I have removed both sockets, I have cleaned and installed my measurements. Sockets look solid. The problem is still going on.
I turn on the ignition, the airbag lamp turns on and off for 5-6 seconds as usual. No problem is seen. It only lights up when I move, that is, when the wheel starts to turn, it lights up again after 5 seconds. It remains.
Can we solve this problem without connecting the computer, guys. I'm waiting for your opinions. Thanks everyone. :))
Vehicle partner adventure 2.0 HDI 2007 model. 06ÖzGüR06 2012-10-16 13:26:43
08.05.2020 17:05 # 2
06OzGuR06
I mean exactly, in the following way, when this problem is caused by sockets, does the ECU enter the fault code and does it have to be deleted? Just share this information, thanks guys. 06ÖzGüR06 2012-10-17 12:07:56
08.05.2020 17:05 # 3
Serkan
My friend, I got out when replacing com2000, it gave airbag error many times then it got lost when we found the com2000 error, we did not delete it, I think it would not give the error again if the problem persists ...
08.05.2020 17:05 # 4
Bugra
Have you recently installed any electronic accessories that are against the originality of the vehicle? Like xenon headlight?
08.05.2020 17:05 # 5
06OzGuR06
[QUOTE = Serco05] Dude I got the exit when changing com2000 too many times it gave the airbag error then it disappeared when we found the solid com2000 error, we did not delete it, I think it would not give the error again if the problem persists ...
[ / QUOTE]
Yes, the problem is still going on. I determined that it wasn't just a socket source. When I turned the steering wheel to the left and right, the airbag light turned on. The horn was not working shortly. The horn is working but the airbag light is on. I guess com2000 replacement was a must. Where do I find a solid output? Or is it possible to change only the airbag wrap in this com2000?
08.05.2020 17:05 # 6
06OzGuR06
[QUOTE = bugrature] Have you recently installed any electronic accessories against the original of the vehicle? Like xenon headlight? [/ QUOTE]
The whole part of the car is original. No change. Possible problem of airbag wrap. :(
08.05.2020 17:05 # 7
Serkan
Dude com2000 unit is broken, if you can find the airbag wrap, only the airbag wrap changes from the outputer Serco05 2012-10-17 12:38:47
08.05.2020 17:05 # 8
06OzGuR06
[QUOTE = Serco05] Dude com2000 unit is broken for sure.
Do we have the opportunity to change only the part of the dressing? Because all the other parts are working normally. It will be very costly to replace it completely.: ((
08.05.2020 17:05 # 9
06OzGuR06
[QUOTE = Serco05]
Dude com2000 unit is broken, if you can find the airbag wrap, only the airbag wrap is changing from the outlet
Let me start researching immediately. Do you know how much it will cost?
08.05.2020 17:05 # 10
Serkan
I do not have information for the winding only, but the comm000 com2000 is sold around 150 TL.
08.05.2020 17:05 # 11
06OzGuR06
[QUOTE = Serco05] I do not have information for the winding only, but I know it from kopmle com2000 is sold around 150 TL. the light is off
Well then we need to find the complete com2000.
08.05.2020 17:05 # 12
erdem661
What kind of shortage can xeno have with airbag?
08.05.2020 17:05 # 13
erdem661
what kind of problem do you explain xenon la air link light
