airbag light flashing
08.05.2020 17:21 # 1
cihanpasam
dear forum masters, the airbag light is flashing, i said before. I couldn't find the cables in question in the back of that seat. Was there a picture on the site? ? And the left speaker is cold. is there anyone who solved it? it was as if I couldn't find the site.
08.05.2020 17:21 # 2
blazes06
If your car does not have an airbag on the sides of the seat, you do not need to look for a cable under the armpits. I would say the windows are open ... If you open the left window, it comes cold through the right speaker, if you open the right glass, the left speaker comes cold. Long storms break off ... The source of this problem is glass wick.
08.05.2020 17:21 # 3
Alicilik
[QUOTE = cihanpasam] dear forum masters, the airbag light is blinking I said before. I couldn't find the cables in question in the back of that seat. Was there a picture on the site? ? And the left speaker is cold. is there anyone who solved it? As if I couldn't find the site I was looking for quite a bit? [/ QUOTE]
I have no idea about the airbag, but I have a suggestion for coldness. I had the same problem. I cut the 10mm sound insulation sponge according to the sponge of the door and attached it to the door with double-sided sponge tape. cut to a near extent.
Alicilik 2013-02-13 01:58:18
08.05.2020 17:21 # 4
Serkan
Check out the subject for the airbag light
http://forum.peugeotturkey.com/forum_posts.asp?tıd=25629&title=206-airbag-zdm
08.05.2020 17:21 # 5
cihanpasam
thanks i saw this link. I did this thing, but I did not have a problem with the cables. And the airbag in this friend's car was just burning. Mine flashes for a second and goes off for a second. always like this. flashing. That is continuous. And this was not the case before the chair pulled back firmly. so armpit & nbsp; I called the cable maybe because it was broken but I couldn't find it.
