Airbag light does not go out
08.05.2020 20:26 # 1
x571
Hi
The airbag lamp does not go out and lights up constantly. Is there anything I can do. This is causing the malfunction. How is the repair
The 3rd stop lamp on the tailgate loosens on bad roads and hits the glass, making a scab sound. How can I compress this as before.
x571 2017-06-28 01:14:54
08.05.2020 20:26 # 2
x571
Topic is up to date
08.05.2020 20:26 # 3
If it is on all the time, it may be that airbag yellowing is broken. In a neglect, unscrew the bottom cover of the steering wheel, there will be sockets. Check them. One of my 206 sockets was loosened. When the 3rd stop comes, disassemble it and check it. Its nails may be broken. check screw screw slots. It can also be broken from the inside, as they often over tighten screws and nuts.
08.05.2020 20:26 # 4
x571
If [QUOTE = sonerkyl] is on all the time, sir, the airbag can be broken. In a neglect, unscrew the bottom cover of the steering wheel, there will be sockets. Check them. One of my 206 sockets was loosened. When the 3rd stop comes, disassemble it and check it. Its nails may be broken. check screw screw slots. It can also be broken from the inside as it is often over tightened with screws and nuts. [/ QUOTE]
Under the driver's seat There was a socket, I tamped it, the airbag light went out I guess the problem was there. There is not a lot of hands in a genus. I'm going to tamp the 3rd stop at a convenient time
08.05.2020 20:26 # 5
Brcbyrktr
Yaw dude, I have the same problem with me. In the past, the odd was burned. The airbag is constantly burning. I opened the cover under the steering wheel, but there is no socket as they say. Mine is what I am wondering. Sockets under the seat.
08.05.2020 20:26 # 6
[QUOTE = Brcbyrktr] Yaw dude, I have the same problem with me, the old one was burned, the airbag is on fire now. I would be glad if you can photograph. [/ QUOTE]
If there is an airbag in the seat, there will be a socket under it.
08.05.2020 20:26 # 7
Brcbyrktr
Just like you said, soner ... I got into various positions in the car in the morning. I will see the cable.
08.05.2020 20:26 # 8
sosyetetr
sister, the airbek lamp does not light up in the horn, it did not play in the horn, it was formed after the front set, now they call it airbek wrap, new 550 TL
