Airbag lamp
08.05.2020 15:28 # 1
friends, for the first time in the car, the airbag lamp came on and it is still on. I played a bit with the underarms, but the warning lamp still did not go out. what should I do?
08.05.2020 15:28 # 2
sercinho
the charging connector is chronically problematic, I will improve
08.05.2020 15:28 # 3
Is that something costly?
08.05.2020 15:28 # 4
sercinho
There is no need to be between 20-30 or so, it will adjust the current, sometimes when it is too short or too low, when the voltage is sent to the electrician.
08.05.2020 15:28 # 5
anil307
my car was burning in my car, the airbag has a place to hurt it, it turns into the airbag when it turns the back of the hand brake and the light stops, I do not know if you have it, but maybe it may have been played without you.
08.05.2020 15:28 # 6
ose
[QUOTE = anil307] my car was burning in my car, there is a place to open and close the airbag, it turns on the airbag when it turns the back of the hand brake, and the light stops, I don't know if you have it in your back, but maybe it might have been played without you [/ QUOTE]
the lights of the two are separate
08.05.2020 15:28 # 7
anil307
I'm sorry =)
08.05.2020 15:28 # 8
ose
[QUOTE = anil307] I'm sorry =) [/ QUOTE]
Do not mention it. We do not know everything, of course, there are many things we do not know. Hopefully it is not com 2000, that is, the whole of the black arms under the steering wheel. Too much tampering right and even tampering is worse than malfunction, there is no malfunction, this time, connect it to the pc, go to the official service, they do not receive money for malfunction detection.
08.05.2020 15:28 # 9
Burak07
can it be something that comes from insurance?
08.05.2020 15:28 # 10
monur
[QUOTE = sercinho] recharging dynamo conjunctor chronic problem varies, I will improve [/ QUOTE]
It makes sense, I also got an error about charging when the Airbag lamp was flashing from time to time, but I don't remember it right now.
08.05.2020 15:28 # 11
burakdmr
I have the same problem .. It burns and goes out lately but it has been burning lately.
I have a strange feeling that when I get the high beam, there is a delay, then it lights up or when I want to burn the parks, I have problems such as the dial lights are lit up late. I wonder why: S: S
08.05.2020 15:28 # 12
I turned the switch on and off, the light is still on. If not, I will connect it to the computer. Let's see what happens.
08.05.2020 15:28 # 13
burakdmr
don't go out then it won't go out .. .. so you also like me, i'm throwing a 500 km long road, it is burning, it is going 50km, then it is going to go 100km, then it is still burning vsvsvs went like this. But the last burn was no intention to return :)
08.05.2020 15:28 # 14
[QUOTE = kankam_743] [QUOTE = anil307] I'm sorry =) [/ QUOTE]
Do not mention it. We do not know everything, of course, there are many things we do not know. Hopefully it is not com 2000, that is, the whole of the black arms under the steering wheel. Too much tampering right and even tampering is worse, no breakdown is found. This time, connect it to the PC. Go to the authorized service.
com 2000 what happens?
08.05.2020 15:28 # 15
sercinho
There is a cost between 500-600 if com2000 but I don't think
08.05.2020 15:28 # 16
I mean, it never happened until ice cream, something like that, I got into the car, I adjusted the seat, there was an up and down lever or I started the car and the lamp went on. I guess it's probably armpit, but I fiddled there and the light didn't go out.
08.05.2020 15:28 # 17
sercinho
connecting to the most beautiful pc may be a problem in socket sockets on the back
08.05.2020 15:28 # 18
[QUOTE = pugti] I turned the switch on and off, the light is still on. If not, I'll connect to the computer and see what happens [/ QUOTE]
I Recommend You To Look Computerized Fault Detection ...
But it seems like there is no serious problem ..
On My Xenons Was Burning From The Problem In The Chassis ...
I Taken It To The Electrician The Chassis Has Changed Its Location No Problem.
08.05.2020 15:28 # 19
ose
These chassis events attracted my attention, it seems to me that there is a sron at the right rear stop, it is dimmer than others and sometimes the right signal accelerates and when I turn right. Also, I saw that the fire burned sometime after the signal.
08.05.2020 15:28 # 20
friends now I came from the service tied the vehicle to the pc. He then said that the airbag on-off switch and the passenger were failing the airbag. If you deleted the error from the PC, your problem did not improve. Bring it to me tomorrow. lights up in two lamps. even sprained the armpit sockets did not happen anyway. The pc did not fail later. but the problem still persists Wall
Page : / 2
