Airbag Heat Problem
08.05.2020 14:02 # 1
Sinan
Why does my car's airbag lamp stay on all the time? It stopped burning while stopping and not ending.
08.05.2020 14:02 # 2
hasimayaz
Our request from our new members:
hakan1203 2009-04-28 13:54:40
08.05.2020 14:02 # 3
hasimayaz
I think the vehicle is X-line. Check the passenger airbag switch. In fact, it would be better to do it on and off. If the light does not go out, the ignition key should be removed from the vehicle and the battery should be removed for a few minutes. plug in again after waiting. If this does not solve the problem, it is necessary to connect the vehicle to the computer. It may be useful to check the bagel connectors:
hasimayaz 2009-04-28 14:06:08
08.05.2020 14:02 # 4
Sinan
I turned off the passenger airbag and it did not happen again with the spare key. I had the computer put the error and could not find it. I looked for a socket under the seat, I couldn't find it for hours. Now let's try to insert the battery terminals and try it. I hope will be
08.05.2020 14:02 # 5
Rfk
If Haşim does what he says and still does not go out, remove the indicator, break or remove the airbag bulb, then replace the indicator. Big smile
08.05.2020 14:02 # 6
pugcu
If [QUOTE = rfk_34] does what the brother says and still does not go out, remove the indicator, break or remove the airbag bulb, then replace the indicator instead of the plug is over Big smile [/ QUOTE]
Not what you say. It's a fake application.
08.05.2020 14:02 # 7
Sinan
I wanted to handle it without the hit and the broken thing :)
08.05.2020 14:02 # 8
Rfk
If [QUOTE = pugcu] [QUOTE = rfk_34] does what the brother has said and still does not go out, disconnect the indicator, break or remove the airbag bulb, then plug the indicator into place. Big smile [/ QUOTE]
I made a reel, of course not, but when there is a light that pushes the limits, let the light bulb break the indicator
08.05.2020 14:02 # 9
hasimayaz
If the vehicle is x-line, there is no airbag and cable harness in the seats.
08.05.2020 14:02 # 10
Rfk
[QUOTE = DavidKane] I wanted to handle the shot without a broken thing :) [/ QUOTE]
If you are a patient, it's a different matter: D
08.05.2020 14:02 # 11
Emin
Well mine was burning too, it doesn't burn anymore :)
The console was disassembled very gently, the light bulb was removed from the lamp holder, it was gently put back in place and
The lamp no longer lights. Without breaking or doing anything :)
08.05.2020 14:02 # 12
Rfk
sure ibo told me your incident I told the friend about that tactic: D
08.05.2020 14:02 # 13
gs5165
mine is on, light is good
08.05.2020 14:02 # 14
Rfk
When the petrol light is on: D
08.05.2020 14:02 # 15
Sinan
Okay, let's light :) but I wonder if it was handed over to the airbag?
08.05.2020 14:02 # 16
MirakGTI
If there is an application you know, share it ..
08.05.2020 14:02 # 17
gs5165
I went to the service for that, so the airbag wouldn't explode on my face, and the service said a piece had to change, it was around 180 lira.
08.05.2020 14:02 # 18
Rfk
What is that piece, tell me, tell me, what is that piece?
08.05.2020 14:02 # 19
HakanGokdemir
O Refik, you are not sure, hee ...
Sure, you removed my bulb LOLClap
08.05.2020 14:02 # 20
gs5165
Well, he was a bit of a cuk but I don't remember his name
Page : / 2
