Airbag fault on the display and screen
08.05.2020 20:32 # 1
Orcun.Dmr
Good evening. While I was on the road a little while ago, I met my friend and pressed the horn, then the driver and passenger airbag light came on, then the airbag fault was lit. I thought of an airbag bandage and I pressed the horn again and the horn rang smoothly. The vehicle has been in me for 7 years and I have not encountered such a problem until now. Why do you think he did something like this and why did he do it? Would it be a problem? Tomorrow I will go long and I will not be able to take the car off the electrician due to the feast. Vehicle 2005 1.4 hdi 307
08.05.2020 20:32 # 2
ALLEX
This is usually caused by comm200 arm failure. Show it to the electrician, the change can reach 550-600 TL.
Check the socket while comm 2000 is being inserted.
08.05.2020 20:32 # 3
Orcun.Dmr
[QUOTE = ALLEX] This is usually caused by the comm200 arm malfunction. Show it to the electrician, the change can reach 550-600 TL. There are also those who do repair.
Check the socket while comm 2000 is being inserted. Maybe it is also caused by socket failure under the airbag [/ QUOTE]
Brother, I even suspended the intercooler because of my studentship. If you keep the exchange fee as you said, I ate the quince. Confused Today, I will not take it anywhere, I bought the car in the garage. As you said, tomorrow we will take it to my electrician and check the sockets and connect it to the computer and look at it. Thank you very much for your comment.
08.05.2020 20:32 # 4
Orcun.Dmr
Yes, the residents of the forum got the same error again, but I couldn't put out what I did. I did not start my car for 3 days, I just got in and started to go to the market and then the airbag and the passenger's airbag light came on in the display. "Passenger Airbag Fault" first on the screen, then "Airbag Fault" wrote on the way, it does not go out for 3 minutes, it repeats the error continuously. I took off the pole and put it on and started it again. When nothing changed, I removed the pole head and closed the hood. I'll try it in the morning. What do you think is the problem? what does it originate from? Note: Everything like wiper arms, horn etc. are working. orçun.dm is 2017-11-19 19:06:47
08.05.2020 20:32 # 5
Orcun.Dmr
Doesn't anyone know in the huge group ?? Cry
08.05.2020 20:32 # 6
[QUOTE = Orçun.Dmr] Yes, the forum residents got the same error again, but I couldn't put it out whatever I did. I did not start my car for 3 days, I just got in and started to go to the market and then the airbag and the passenger's airbag light came on in the display. "Passenger Airbag Fault" first on the screen, then "Airbag Fault" wrote on the way, it does not go out for 3 minutes, it repeats the error continuously. I took off the pole and put it on and started it again. When nothing changed, I removed the pole head and closed the hood. I'll try it in the morning. What do you think is the problem? what does it originate from? Note: Everything about wiper arms, horn etc. is working. [/ QUOTE]
Orçun brother, there are two reasons for the problem, one armpit sockets, two com2000 headlight wiper arms, first of all, if you have your car connected to the computer and look at the error codes, my brother will come out.
08.05.2020 20:32 # 7
Orcun.Dmr
[QUOTE = sonerkyl] [QUOTE = Orçun.Dmr] Yes, the residents of the forum got the same error again, but I could not extinguish whatever I did. I did not start my car for 3 days, I just got in and started to go to the market and then the airbag and the passenger's airbag light came on in the display. "Passenger Airbag Fault" first on the screen, then "Airbag Fault" wrote on the way, it does not go out for 3 minutes, it repeats the error continuously. I took off the pole and put it on and started it again. When nothing changed, I removed the pole head and closed the hood. I'll try it in the morning. What do you think is the problem? what does it originate from? Note: Everything about wiper arms, horn etc. is working. [/ QUOTE]
I checked Soner underarm sockets, there is no problem in them. I am waiting for my electrician friend will come out after work and connect to the computer and check but I wanted to get information from you until I came. Smile The lights went out while trying to get the tire to be tested, but after 50 meters, it turned on again. LOL
08.05.2020 20:32 # 8
Orçun brother, I think the problem is to make a measurement of your friend like com2000. I also say check the inner fuse box
08.05.2020 20:32 # 9
Orcun.Dmr
In the evening, we connected it to the computer and looked at it, Soner brother, but he did not read, Peugeot software that came to the computer with the thought of absentness did not read the computer. LOL Tonight we will understand what the problem is. Smile
08.05.2020 20:32 # 10
axoyum
There is a spring-like airbag coil wrapped around the steering column that is broken. The inexpensive and general solution is to cancel the steering wheel. Connect a 100 ohm resistor between the two ends of the winding as follows and the problem is solved.
08.05.2020 20:32 # 11
Orcun.Dmr
[QUOTE = axoyum] There is a spring-like airbag coil wrapped around the steering column that is broken. The inexpensive and general solution is to cancel the steering wheel. Connect a 100 ohm resistor between the two ends of the winding as follows and the problem is solved. [/ QUOTE]
I wouldn't cancel Airbags even if I absolutely and definitely die. The lights went out on my electrician friend, we connected it to the computer, the error code did not appear and the Airbag lights did not come on. Smile
orçun.dm is 2017-11-25 19:41:47
08.05.2020 20:32 # 12
Adem Kurtuldu
My brother is a bit off topic, but what's the point of installing the intercooler, is there anything extra in the car?
08.05.2020 20:32 # 13
[QUOTE = Orçun.Dmr] [QUOTE = axoyum] There is a spring-like airbag coil wound around the steering column, it is broken. The inexpensive and general solution is to cancel the steering wheel. Connect a 100 ohm resistor between the two ends of the winding as follows and the problem is solved. [/ QUOTE]
I am glad that it has improved, but my brother will come across in the future. It is possible to repair it around 150-200 TL. or you will get a zero room, as you know, cost about 600-700 TL.
08.05.2020 20:32 # 14
Hodja, I absolutely disagree with such a thing
08.05.2020 20:32 # 15
uzunca961
Canceling the airbag is not very smart, it not only fixes the error but also saves it. When doing this, it is necessary to think more than two.
08.05.2020 20:32 # 16
Orcun.Dmr
[QUOTE = Adam Kurtuldu] my brother is a bit off topic but what is the purpose of installing intercooler, is there anything extra in the vehicle? [/ QUOTE]
Unfortunately, I could not wear it yet, my brother Turbom broke down, I switched to hybrit turbo research, so the material you will understand has shaken a little. There is nothing extra in the vehicle right now, but in the future, soft software, injector enlargement, etc. will come slowly. Smile
08.05.2020 20:32 # 17
Orcun.Dmr
[QUOTE = sonerkyl] [QUOTE = Orçun.Dmr] [QUOTE = axoyum] There is a spring-like airbag wrap around the steering column, it is broken. The inexpensive and general solution is to cancel the steering wheel. Connect a 100 ohm resistor between the two ends of the winding as follows and the problem is solved. [/ QUOTE]
If it burns again, I will leave the car to my friend. I am strange that the fault lamp is on the display and I do not officially get on the vehicle. Smile
08.05.2020 20:32 # 18
Orcun.Dmr
[QUOTE = lengthy961] Canceling the airbag is not very smart, it just fixes the error and saves it safely. While doing this, it is necessary to think more than two [/ QUOTE]
Exactly, my life safety is more important than anything else. If it burns again, I will have it repaired. Smile
08.05.2020 20:32 # 19
Orcun.Dmr
Friends airbag light has gone out and is not lit in 1 month. I think I started to think that my problem was about sockets.
08.05.2020 20:32 # 20
Selcuk55
Certainly I do not open the airbag after soner, the resistance in the crash just deceive the vehicle.
Page : / 2
