Airbag fault help
08.05.2020 15:00 # 1
friendkalp
Hello friends, I bought the model tool 307 2004 and it got the same error when I received the airbag fault message. I connected it to the computer on the right side & nbsp; issues & nbsp; they said there is. I looked under the right seat today, 4 cables are coming, but 3 are connected, one is not connected & nbsp; they have no socket taped.and the cable from the seat and the cable colors from the airbag are different.
08.05.2020 15:00 # 2
The subject of the meeting will not respond to anyone without hurting and introducing yourself. I advise you to read the forum rules ...
08.05.2020 15:00 # 3
friendkalp
I'm sorry, thank you
08.05.2020 15:00 # 4
friendkalp
I am waiting for help If you have other friends who use 307, I will be happy if they share the cable connection.
08.05.2020 15:00 # 5
GiTaRRa
If you go to a good electrician who connects the machine to the machine and sees the problem, he will do it.
08.05.2020 15:00 # 6
friendkalp
tþkler
08.05.2020 15:00 # 7
The AIR BAG light on the instrument panel did not go out when I started the car today in the morning. When I first switched on the ignition, it would light up and go out as soon as it starts. this time did not go out. I came to work like this. I don't know if there is a damage. Should I go to industry or service for that?
08.05.2020 15:00 # 8
werty
walla mate is there if there is a problem in the airbag cables, but if there is no, measure the battery voltage.
respects
08.05.2020 15:00 # 9
gozem
In my 2004 307 vehicle, abs and airbag fault was constantly burning.
I made it for 40 TL.
First, I connected the computer to the driver. We received a warning that the 2nd open circuit.
steering airbag was disconnected.
if abs; front wheels removed, speed sensor readers removed
cleaned and installed.
The last one was connected to the pc and the faults were deleted.
such issues do not delete without fixing the problem
(for friends who do not know)
[I] [/ I]
08.05.2020 15:00 # 10
Eyup Duygun
If your airbag lamp is on, it does not work in the event of an accident without Allah showing it. plug it in.
