airbag fault !!
08.05.2020 16:45 # 1
MuratUlg
I have read many times in the forum, when this malfunction came out, plugging the socket under the driver's seat off most of the time would fix the problem, but could I tell a friend who has never been disconnected?
08.05.2020 16:45 # 2
toga406
Do not have any claws, open and detach the connections lightly with a screwdriver
08.05.2020 16:45 # 3
MuratUlg
[QUOTE = toga406] does not have tabs open and gently open the connections with the screwdriver [/ QUOTE]
I'll try it out thanks.
08.05.2020 16:45 # 4
monur
I got the same error for a while and the problem was the driver's seat belt fastening. They cleaned the socket with contact spray and put it in place, the warning light and the text on the trip computer disappeared without the need to delete the fault from the pc. Fortunately, there is no sound for 1.5 years.
08.05.2020 16:45 # 5
peugeot22
I also had this error recently, I just moved the cables a little without disconnecting the socket under the driver's seat, the error and the light went out when I started. A problem that usually occurs in the 206s.
08.05.2020 16:45 # 6
toga406
Simple malfunctions, but if Allah doesn't show up, he doesn't take over in the event of an accident. then who cuts the speed of the grim reaper.
08.05.2020 16:45 # 7
MuratUlg
I still could not remove the socket does not even dislodge :(
08.05.2020 16:45 # 8
onurcelikoz
me too, the airbag light never comes on. a master at the maslak connected the computer, but made a statement like either from the cable or from the brain.
08.05.2020 16:45 # 9
black_rock
the airbag lamp does not light on me :(
08.05.2020 16:45 # 10
peugeot22
I have an idea for the friends whose airbag light never turns on,
Either the led light in it is broken or the old owners have deliberately distorted or removed the leds in the airbag light to hide their broken airbags.
I went to the shop and when I asked if he would turn on the fault lights, he said, if the man turns on the fault lights directly, we remove the burning fault lights, & nbsp;
As if the lights came out, the fault is over:) & nbsp;
