Airbag fault ..
08.05.2020 16:15 # 1
Friends have said that after traveling for 700 km with my vehicle, thank goodness there was no problem, 5 km to the house..airbag said fault .. after the passenger said that the airbag was disabled, there is an airbag error. it is not a constant error, it is not intermittent, it is intermittent, sometimes it gives error on the screen sometimes it does not give on the screen. Is there a problem with the place in the open position. Is there any solution proposal to you?
08.05.2020 16:15 # 2
Something similar happened to me, but he gave it in abs fault & nbsp; at the same time, the problem was in the charging dynamo, they did it :)
08.05.2020 16:15 # 3
tazmaniac
battery, com2000, as the friend said, there may be a problem with the charger or even the bside.
08.05.2020 16:15 # 4
exactly as hocam.bi does not do bi, i think there is lack of contact..when he clears the error, he gives an error again.
08.05.2020 16:15 # 5
tazmaniac
No, I don't think it is in the key, so I would say it might break down in a place to be oxidized, but I don't think so ... I do not know it as passenger airbag, but I guess the passenger airbag is on the front chest, the tape is going behind the back, but I guess the cables are. look at the sockets i think
08.05.2020 16:15 # 6
The same thing happened to me the other day, the master pulls the metal from the cold, the cables did not contact them, he did not do it again, but I will replace the battery tomorrow, and the bar is hardly working every morning.
08.05.2020 16:15 # 7
Akifff
It was just giving me the Airbag error, it was making the first time, not on the road, not on the road, & nbsp; mine changed the rollers on the airbag at the steering wheel, I was not in contact ,,, the problem was solved like this
08.05.2020 16:15 # 8
@huseyinturk
& nbsp; I guess you have had a problem, too .. I have been in trouble for two days, the car does not give a mistake. Thank you.
08.05.2020 16:15 # 9
I Love My Pug
The abs lamp was blinking on me, the problem was on the sensors, take off the rims and turn it on again, they said that lamp is like that.
08.05.2020 16:15 # 10
teacher, if the computer does not show the cause of the error, have the cables under the armpit also checked.If you are traveling on the wet road for a long time, there may be problems with the sensors on the chassis due to wetting or one of the passengers in the back seat may have hit something under the forearms. automander is the capital auto electric master in industry, which does this best in Ankara.
08.05.2020 16:15 # 11
Meanwhile, the ABS malfunction lamp lights up on me, but I know the problem. Mine is on when it goes over 50km, because of this one of the ball bearings makes a small jerk, so the abs cannot work properly and cancels and gives pain.
08.05.2020 16:15 # 12
peugeotefe
If there is a contactlessness in the airbag coil in com2000, it will make it happen.
08.05.2020 16:15 # 13
borgetti85
friends stay away from the capital auto destroyed my car
08.05.2020 16:15 # 14
C@GL@R
I think the problem has been solved.
